[mapguide-users] Fusion and Open layers Coordinate systems
Mike Adair
madair at dmsolutions.ca
Wed Oct 7 13:53:35 EDT 2009
It's a shame MapGuide doesn't use EPSG codes :-)
OpenLayers applications typically would use Proj4js to do client side
transformations which is based on PROJ.4 which can use EPSG codes and/or
custom initialization parameters. I haven't heard of anyone converting
CS-Map to Javascript.
Mike
Scott hameister wrote:
> It's a shame OpenLayers doesn't use mentor/CS-Map...I thought I read
> somewhere that it was going to? Anyone?
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jason Birch
> Sent: Wednesday, October 07, 2009 11:28 AM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] Fusion and Open layers Coordinate systems
> I know this is neither here nor there, but I believe there are many
> valid projections that do not have EPSG codes. Defaulting to LL when
> many "non-standard" CS are liner-units-based may not be the best
> approach. Would it not be possible to disable coordinate transforms if
> there is no code available?
> Jason
> On 2009-10-07, Mike Adair <madair at dmsolutions.ca> wrote:
>> I'm currently working on a patch to retrieve the projection info from
>> the map definition for MapGuide. The problem is that MG uses WKT and
>> OpenLayers/Fusion uses EPSG codes and MG doesn't always have an EPSG/WKT
>> mapping available. So I will be implementing this so that if MG returns
>> a valid EPSG code it will use that, otherwise it will take a value from
>> the ApplicationDefinition file, and if there still isn't an EPSG code
>> available then the projection will be set to the OpenLayers default of
>> EPSG:4326.
>> Mike
>> Flipper wrote:
>>> Im trying my hand at some Open Layers programming. I'm trying to set the
>>> maps
>>> Coordinate system to match Mapguides, So I decided to peek into
> Fusion....
>>> One thing for the life of me I can't find is where fusion sets the
>>> OpenLayer
>>> Maps Coordinate system. I know Open layers uses Proj 4, and Mapguide Can
>>> use
>>> both cs-map and Proj4...I know how to get the coordinate system
>>> Description
>>> out of Mapguide...But how do I push it back into OpenLayers Using my
>>> PROJCS
>>> system...
>>> Or worded Much simpler...How/Where does Fusion do this to openLayers...I
>>> want this to work on anymap...so I don't want to hard code a EPSG code
>>> into
>>> it, and several users will have Non PROJ4 coordinate systems, like Local
>>> County Coordinate systems that CS-MAP allows them to use...
>>> ANYONE?
>> Michael Adair
>> Senior Software Architect
>> DM Solutions Group Inc.
>> Office: (613) 565-5056 x26
>> http://www.dmsolutions.ca
>> http://research.dmsolutions.ca
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
Michael Adair
