[mapguide-users] RE: MGOS 2.1 Load Pakage not working
Dave Wilson
dave.wilson at autodesk.com
Thu Oct 8 13:07:10 EDT 2009
Increase the max file upload setting in your php.ini to something bigger than your largest anticipated package. The default is 2M.
Dave
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Fraser Burgess
Sent: Thursday, October 08, 2009 9:21 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] MGOS 2.1 Load Pakage not working
I've installed MGOS 2.1 (.Net / IIS Configuration) and have logged into the site administrator. The list of packages is populated as it should be and the correct package name has been selected in the list. I select "Load Package" and the page scrolls to the top and nothing happens. I've been clicking around in the site administrator and have noticed some other links that don't seem to work.
I checked the configure services and it appears that all the links are pointing to the right spot (I used all the default directories in the install).
Any ideas?
Fraser
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091008/a9d56de2/attachment.html
