[mapguide-users] RE: MGOS 2.1 Load Pakage not working
Fraser Burgess
fburgess at lakelandenergy.com
Fri Oct 9 11:25:08 EDT 2009
Good suggestion
Tried it and everything looks like it is pointing to appropriate MGOS
directories.
Just as a note. This is a fresh install of Win2003 Server - MGOS was
the first and only thing to be installed (outside of adding IIS).
Cheers,
Fraser
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
Sent: Friday, October 09, 2009 11:11 AM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] RE: MGOS 2.1 Load Pakage not working
Maybe there are issues with your PHP installation? Try a phpinfo page in
your root MapGuide folder and see if the pathing and everything is
correct. Maybe you have another php instance that is causing a conflict?
Dave
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Fraser
Burgess
Sent: Friday, October 09, 2009 9:06 AM
Thanks Dave,
Still no luck
Fraser
Sent: Thursday, October 08, 2009 1:07 PM
Subject: [mapguide-users] RE: MGOS 2.1 Load Pakage not working
Increase the max file upload setting in your php.ini to something bigger
than your largest anticipated package. The default is 2M.
Dave
Burgess
Sent: Thursday, October 08, 2009 9:21 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] MGOS 2.1 Load Pakage not working
I've installed MGOS 2.1 (.Net / IIS Configuration) and have logged into
the site administrator. The list of packages is populated as it should
be and the correct package name has been selected in the list. I select
"Load Package" and the page scrolls to the top and nothing happens.
I've been clicking around in the site administrator and have noticed
some other links that don't seem to work.
I checked the configure services and it appears that all the links are
pointing to the right spot (I used all the default directories in the
install).
Any ideas?
Fraser
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20091009/4dbd238a/attachment.html
