[mapguide-users] Maroon Theme and tooltips doesn't show
Chris Claydon chris.claydon at autodesk.com
Thu Oct 15 10:07:28 EDT 2009
It could be that the z-order is causing the map tips to show up behind the map. Take a look at the jxtheme.css file in the slate and maroon templates, and search for the settings for #Map. The Slate version specifies the z-index for the map, the Maroon version doesn't, so adding a similar setting might solve the problem.
Hope that helps!
Chris.
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jose Cerrejon
Sent: Thursday, October 15, 2009 3:50 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Maroon Theme and tooltips doesn't show
I'm using this theme in a proyect, but I'm testing all posible Mapguide betas
and RC, and I don't get to work the tooltips. I don't know if it's a
Mapguide or a Fusion problem. In the default template it's ok.
Test: Sheboygun.mgp+IIS+PHP+Mapguide 2.1.0.4283-RC1 in a VirtualBox with
WinXP.
Thks.
View this message in context: http://n2.nabble.com/Maroon-Theme-and-tooltips-doesn-t-show-tp3828284p3828284.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
