[mapguide-users] Maroon Theme and tooltips doesn't show
Jose Cerrejon gis at mapas-sll.com
Thu Oct 15 10:45:46 EDT 2009
Thanks! That's it!
I hope somebody go to the SVN and fix it!.
Mike Adair wrote:
> It looks like in the Maroon template index.html you need to change from:
> <div id="Maptip"></div>
> to:
> <div id="MapTip"></div>
> (note the upper case T).  As it is, Fusion can't find the DOM element
> for the Maptip and so won't instantiate the widget.
> Mike
> Jose Cerrejon wrote:
>> I'm using this theme in a proyect, but I'm testing all posible Mapguide
>> betas
>> and RC, and I don't get to work the tooltips. I don't know if it's a
>> Mapguide or a Fusion problem. In the default template it's ok.
>> Test: Sheboygun.mgp+IIS+PHP+Mapguide 2.1.0.4283-RC1 in a VirtualBox with
>> WinXP.
>> Thks.
View this message in context: http://n2.nabble.com/Maroon-Theme-and-tooltips-doesn-t-show-tp3828284p3829748.html
