[mapguide-users] Selecting in Fusion Template (Slate)
Adam Roy
civilrights3 at gmail.com
Tue Oct 20 15:21:12 EDT 2009
Hello all,
I'm new to MapGuide, only been working with it a couple weeks now.
I'm using MapGuide 2.0.2 and Fusion 1.1.0
I have a normal MapGuide application that works fine with the map that i
have created.
I'm now trying to take that application and replicate it using in one of the
Fusion templates (slate to be exact).
However, whenever I try to do a selection on the map (be it a single object
or within an area) I keep getting the following error...
http://n2.nabble.com/file/n3860728/ajaxerror.png
I was wondering if there was something basic I missed changing in the
application definition or if there is a setting in my map/layers that i need
to enable/disable
Thanks,
~Adam
View this message in context: http://n2.nabble.com/Selecting-in-Fusion-Template-Slate-tp3860728p3860728.html
