[mapguide-users] Passing username and password into url with fusion
Jackie Ng jumpinjackie at gmail.com
Tue Oct 20 18:51:00 EDT 2009
The simplest method is to make a server-side wrapper, where you generate the
MapGuide session id.
Then redirect to the index.html passing an additional parameter:
Session=<your generated session id>
- Jackie
Fraser Burgess wrote:
> Is there a trick to passing username and password into a URL with
> Fusion:
> A URL such as
> http://mywebsite.com/mapguide2010/fusion/templates/mapguide/TMOslate/ind
> ex.html?ApplicationDefinition=Library%3a%2f%2fTMO%2fLayouts%2fTMO%20Map.
> ApplicationDefinition&LOCALE=en&USERNAME=Anonymous&PASSWORD=
> still brings up the log in prompt
> Fraser
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Passing-username-and-password-into-url-with-fusion-tp3860654p3861781.html
