[mapguide-users] Passing username and password into url
with fusion
Andy Morsell
amorsell at spatialgis.com
Wed Oct 21 00:12:20 EDT 2009
It looks like this will be fixed in MGOS 2.1 final. You must be using the 2.1
beta from May where that problem existed (it worked fine in prior releases).
You can install 2.1 RC1 from here which should have the fix:
http://download.osgeo.org/mapguide/testing/
By the way, the Fusion Trac ticket for this issue is:
http://trac.osgeo.org/fusion/ticket/263
Andy
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of ary_s
Sent: Tuesday, October 20, 2009 8:30 PM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] Passing username and password into url with
fusion
the example works for IE and Chrome but my FF still ask username and
password.
thanks
Andy Morsell wrote:
> No, Fusion does not support that. See this issue on the Fusion Trac:
> http://trac.osgeo.org/fusion/ticket/105
> You can, however, pass a valid SESSION at the URL to bypass the login
> prompt. See the attached example.
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> 47° 46' N 116° 49' W
> www.SpatialGIS.com
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Fraser
> Burgess
> Sent: Tuesday, October 20, 2009 12:06 PM
> To: MapGuide Users Mail List
> Subject: [mapguide-users] Passing username and password into url with
> fusion
> Is there a trick to passing username and password into a URL with Fusion:
> A URL such as
> http://mywebsite.com/mapguide2010/fusion/templates/mapguide/TMOslate/index.h
> tml?ApplicationDefinition=Library%3a%2f%2fTMO%2fLayouts%2fTMO%20Map.Applicat
> ionDefinition
> <http://mywebsite.com/mapguide2010/fusion/templates/mapguide/TMOslate/index.
> html?ApplicationDefinition=Library%3a%2f%2fTMO%2fLayouts%2fTMO%20Map.Applica
> tionDefinition&LOCALE=en&USERNAME=Anonymous&PASSWORD=>
> still brings up the log in prompt
> Fraser
> mapguide-users mailing list
View this message in context:
http://n2.nabble.com/Passing-username-and-password-into-url-with-fusion-tp3860654p3862870.html
