[mapguide-users] Measuring areas
Zac Spitzer zac.spitzer at gmail.com
Fri Oct 23 22:59:42 EDT 2009
can you file a ticket in trac ?
thats normal process and then post an email to mg -internals and
request a review?
On Thu, Oct 22, 2009 at 12:46 AM, web <web at infogeo.ch> wrote:
> Hello all,
> past 2 years I've done this contribution to MG (distance + area). It seems that the code has only been partially integrated, without area measure. I don't know why it has not been ported, but I suspect it was because the areas were only available in meter and for other some reasons...
> I put in attachment what I did and what I've sent to the MG project. This widget is working with fusion and MG V 1.2. Because now the project has moved to Openlayers, it would require some changes to make it working again...
> Regards,
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
