[mapguide-users] Add features to SQL Server Spatial
    Jamo
    adam.jamison at portbris.com.au
    Mon Oct 26 22:11:50 EDT 2009
I think mapguide api only exposes sdf write capabilities?
Might have to do it through fdos
Rodolfo Moreno wrote:
> why don't you insert sql features using SQL spatial scripts?
> Regards,
> Gunter Becker wrote:
>> Is there at least anyone who had successfully added features to SQL
>> Server 2008 Spatial with the MapGuide API. What could cause problems when
>> adding features to the database?
>> I think there was another thread (
>> http://n2.nabble.com/MSSqlServer-Spatial-problem-tt3148712.html#a3154109
>> MSSqlServer Spatial problem ) that describes a similar problem.
>> But this problem had to do with 3-dimensional point what is not what i am
>> using. I am using x,y-points.
>> Any ideas?
>> Gunter
>>> Hi,
>>> i'm trying to add features to an existing FeatureSource via MapGuide
>>> API. I've created a new schema with Autodesk Map 2010, created some
>>> polygons, created my feature source and layer in MapGuide Studio,
>>> inserted the layer in my map and it shows up fine.
>>> OK, displaying the features works fine. But when trying to add some
>>> features via the digitize function and my serverside code nothing
>>> happens. It seemes that the code works fine, cause it is the same code
>>> that I use with sdf feature sources and the code throws no error in
>>> debug mode. The "UpdateFeatures"-Methode seems to work but when looking
>>> into the SQL Server table there is no entry and therefore no object on
>>> the map. When logging SQL-Statements with SQL Profiler no activities
>>> were logged.
>>> Only thing that works is deleting an existing map from the
>>> featuresource. So maybe it has to do something with the
>>> coordinatesystem? But as far as I understand the geometry-column of my
>>> databasetable doesn't need a coordinatesystem assigned!
>>> Someone who had same problem? Any ideas?
>>> Thanks, Gunter
View this message in context: http://n2.nabble.com/Add-features-to-SQL-Server-Spatial-tp3878130p3896621.html
