[mapguide-users] Oracle 10g Standard
djonio DJonio at miami-airport.com
Thu Oct 29 12:45:24 EDT 2009
James,
We have used Oracle XE 10g and Oracle Enterprise 10.2.0.3 for a couple years
now with good success.
About two million geometry objects. Oracle works well as does the .8
versions of SL King Oracle FDO Provider. (There was some bleeding prior to
the .8 versions of SL King ... ;-)
We use Oracle's SDO_GEOMETRY object for all. Since Oracle's implementaion
has been around for a lomg long time there is very good forum and other
support. IMHO, if you spend the time to learn and use Oracle and the Oracle
geometry objects you will be set. Your datastore, compatability and
expandability will never again be an issue.
r,
dennis
View this message in context: http://n2.nabble.com/Oracle-10g-Standard-tp3910485p3914023.html
