[mapguide-users] Coordinate system transformation
mighty_duck msiljegovic at gmail.com
Tue Sep 1 05:25:48 EDT 2009
Hello,
Im having next problems during performing coordinate system transformation:
Here is the code
             MgSpatialContextReader context;
             context =
featureService1.GetSpatialContexts(layerFeatureResources1, true);
             context.ReadNext();
             string coordSys = context.GetCoordinateSystemWkt();
             MgCoordinateSystemFactory coordSysFac = new
MgCoordinateSystemFactory();
             MgCoordinateSystem cs;
             cs = coordSysFac.Create(coordSys);
             string mapCoordSys = map1.GetMapSRS();
             MgCoordinateSystem csNew;
             csNew = coordSysFac.Create(mapCoordSys);
             MgCoordinateSystemTransform coordSysTransf;
             coordSysTransf = coordSysFac.GetTransform(cs, csNew);
             Problem starts at context object (second line) where I recieve
exception "index is out of the range".
Does anyone know what can be a problem? Im using Oracle as data source!!!
thanks in advance
regards
View this message in context: http://n2.nabble.com/Coordinate-system-transformation-tp3559335p3559335.html
