[mapguide-users] Temporary Line String Layer not showing up on runtime map.
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Thu Sep 3 04:54:37 EDT 2009
There is an area of MG that could be made easier :)
The best way to troubleshoot this, is to write the FeatureSource and
LayerDefinition to Library://
You need to be Administrator to do so.
Once written to Library://, you can use a tool such as Maestro or Studio
to examine the FeatureSource and LayerDefinition,
and see what parts are off.
I've looked through the code and found no obvious errors.
Also, be sure to check the error log, as MG occasionally writes error
info there.
Regards, Kenneth Skovhede, GEOGRAF A/S
rsri skrev:
> Hello folks.
> I have read several posts and solutions where people have come across this
> problem, but I couldn't find a definitive solution. I would indeed be very
> grateful if someone may please help me.
> The task is to allow the user to click and create a digitized line and then
> display it on the runtime map. The coordinates are sent to the aspx page
> which does some processing and gets the length of each segment. All this
> works fine.
> The problem is when showing this line string on the map. The feature service
> is created successfully, the layer is created, feature source is added to a
> new layer, the layer gets added to the map and shows in the legend, but the
> line string feature does not show on the map !!!
> I am attaching the .cs file as a text file and pasting the
> layerdefinition.xml. Can some one please help me with this.
> Thanks
> Code file is:
> Layer Definition is as follows:
> <?xml version="1.0" encoding="UTF-8"?>
> <LayerDefinition version="1.0.0"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:noNamespaceSchemaLocation="LayerDefinition-1.0.0.xsd">
>  <VectorLayerDefinition>
>    <!--<ResourceId>MeasureLength</ResourceId>-->
>    <ResourceId />
>   <FeatureName>Default:MeasureLength</FeatureName>
>   <FeatureNameType>FeatureClass</FeatureNameType>
> <PropertyMapping>
>   <Name>LENGTH</Name>
>   <Value>LENGTH</Value>
>   </PropertyMapping>
> <PropertyMapping>
>   <Name>UNITS</Name>
>   <Value>UNITS</Value>
>   </PropertyMapping>
>    <PropertyMapping>
>      <Name>ID</Name>
>      <Value>ID</Value>
>    </PropertyMapping>
>   <Geometry>GEOM</Geometry>
> <VectorScaleRange>
>   <LineTypeStyle>
>     <LineRule>
>       <LegendLabel />
>       <LineSymbolization2D>
>         <LineStyle>Solid</LineStyle>
>         <Thickness>0.5</Thickness>
>         <Color>FF808080</Color>
>         <Unit>Millimeters</Unit>
>       </LineSymbolization2D>
>     </LineRule>
>   </LineTypeStyle>
> </VectorScaleRange>
> </VectorLayerDefinition>
> </LayerDefinition>
> http://n2.nabble.com/file/n3566482/CustomTool.txt CustomTool.txt
