[mapguide-users] MaestroAPI - Possible error in RenderRuntimeMap
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Thu Sep 10 12:13:44 EDT 2009
For some reason the DPI property is not set-able in the MapGuide API,
but works just fine with the WebAPI.
So you are correct, the DPI setting is ignored.
Not sure if it is per-design or a bug in the API.
My workaround is something like this:
LocalNativeConnection realCon; //Assigned somewhere
ServerConnectionI renderCon;
if (dpi != 96) //96 is the default API
renderCon = new HttpServerConnection(new Uri(....),
realCon.SessionId, null, true);
else
renderCon = realCon;
renderCon.RenderRuntimeMap(....); //DPI
Regards, Kenneth Skovhede, GEOGRAF A/S
Gunter Becker skrev:
> Hi,
> when using RenderRuntimeMap methode of the Connection object it seems
> that the dpi value takes no effect. I'm trying to render the map with
> 150 dpi but it renders like using 96 dpi.
> When rendering through the WebTierApi with the exact same values (150
> dpi) it shows up as expected.
> In my former project I used the WebTierApi methode but thought that
> since using Maestro I could switch to the RenderRuntimeMap methode.
> Is there something I am missing or ist this an error in MaestroAPI?
> Thanks, Gunter
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090910/7cf893fb/attachment.html
