[mapguide-users] Unable to select/highlight objects - MGE 2010Update 1 & AJAX Viewer
大高 大輔 dootaka at solxyz.co.jp
Thu Sep 10 21:07:22 EDT 2009
 > Mark
Are you using Multi-Schema?
I'm having the same problem (maybe same) after upgrading to MGE 2010 Update 1.
Any idea?
Best, Regards.
[issue]
selecting is OK, but highlighting is NG
[target feature]
point feature (line and area are OK)
[feature source]
database: oracle 11g
feature schema: multi schema
[details]
// Pattern A
layer A: belong to SchemaA
layer B: belong to SchemaB
map: only 2 layer (layerA and layerB)
layer A - Drawing Order 0 (Upper)
layer B - Drawing Order 1 (Lower)
--> layerA is NG, layerB is OK
// Pattern B
layer B - Drawing Order 0 (Upper)
layer A - Drawing Order 1 (Lower)
// Pattern C
layer C: belong to SchemaA
map: only 3 layer (layerA, layerB, layerC)
layer C - Drawing Order 2
--> layerA is OK, layerB is NG, layerC is OK
