[mapguide-users] RE: parent.parent.parent.mapFrame - AJAX vs FUSION
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Thu Sep 17 02:36:57 EDT 2009
For future problems, I can recommend the FireBug plugin for Firefox or
the debugger in IE8 (Press F12).
Using either tool, you can set a breakpoint in your JS code, and once
paused, you can inspect the variables avalible.
You can then easily see what parent and opener points to, and this
should help you figure out how to fix issues like this.
Regards, Kenneth Skovhede, GEOGRAF A/S
Chris Claydon skrev:
> 'parent' takes you to the frame that is the parent of the one you're
> running the script in. The GetParent() method as defined below looks
> for 'Fusion' to be defined either in the direct parent or the parent
> of that frame. If you're launching in a new window, you'll never get
> to a parent that has Fusion defined. I think you need to use 'opener'
> instead...
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Fraser
> Burgess
> *Sent:* Wednesday, September 16, 2009 2:04 PM
> *To:* MapGuide Users Mail List
> *Subject:* RE: [mapguide-users] RE: parent.parent.parent.mapFrame -
> AJAX vs FUSION
> So GetParent() worked when things were called with
> "parent.parent.parent.mapFrame"; however, what if I have something in
> AJAX like this://
> /function OnPageLoad()/
> /    parent.ZoomToView(<%= GetRequestParameters()["X"] %>, <%=
> GetRequestParameters()["Y"] %>, <%= GetRequestParameters()["Scale"]
> %>, true);/
> I then modify by adding your code below and then try:
> /function GetParent()/
> /            if (parent.Fusion) {/
> /                return parent;/
> /            } else if (parent.parent.Fusion) {/
> /                return parent.parent;/
> /    GetParent().ZoomToView(<%= GetRequestParameters()["X"] %>, <%=
> %>, true);/
> This code is using the sample gotopoint.aspx file.  When I select the
> link that activates this gotopoint, the URL contains the X Y and scale
> http://172.16.186.38/mapguide2010/UtilityMap/gotopoint.aspx?X=632593.974151717&Y=4989398.03115329&Scale=25000
> <http://172.16.186.38/mapguide2010/UtilityMap/gotopoint.aspx?X=632593.974151717&Y=4989398.03115329&Scale=25000>
> which should be passed into this onPageLoad() function.  However it
> appears that nothing is firing for OnPageLoad -- so when I click the
> link nothing happens, no error message or anything.
> Can anyone help with this problem?  Also, can anyone point me to
> something that would help explain this parent.parent. syntax?  I'm not
> really certain why at one point we would use parent.function() vs
> parent.parent.parent.function() etc.
> Thanks again
> Fraser
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Berdel,
> Brian
> *Sent:* Wednesday, September 16, 2009 9:02 AM
> *Subject:* [mapguide-users] RE: parent.parent.parent.mapFrame - AJAX
> vs FUSION
> If you want to add the reference to your fusion index page, add the
> following to your aspx (task pane) page
>                 return parent;
> Then you can call functions in the same way as before but substitute
> GetParent()./DigitizePoint(OnPointDigitized);/
> Brian Berdel
> McMahon Associates, Inc.
> p: 215.283.9444 x 260
> www.mcmtrans.com <http://www.mcmtrans.com>
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Chris
> Claydon
> *Sent:* Tuesday, September 15, 2009 4:43 PM
> vs FUSION
> I think you should be able to reference the MapGuideViewerAPI.js
> script from your aspx page, and then just call DigitizePoint directly
> without any window.top or parent references.
> It should also be possible to add a reference to MapGuideViewerAPI.js
> to the index.html file in the Fusion template you're using, and
> reference it using window.top...
> It's been a while since I've played around with this stuff, so someone
> else may be able to provide specifics...
> Burgess
> *Sent:* Tuesday, September 15, 2009 1:40 PM
> *Subject:* [mapguide-users] parent.parent.parent.mapFrame - AJAX vs FUSION
> Hi List,
> I'm making steady progress with my project and learning many things
> about MapGuide along the way thanks largely to the help from those on
> this list -- many thanks to those who have helped so far
> From what I can tell parent.parent.parent.mapFrame is how the map
> frame is referenced from the task pane in the AJAX viewer.  I have
> been reading posts about how this is referenced in Fusion and it seems
> the /MapGuideViewerAPI.js/ file has a bit of info.  Unfortunately I'm
> having a bit if trouble putting the pieces together and was hoping
> that someone here may steer me in the right direction.
> In both AJAX and FUSION I'm working from the taskpane and using the
> markup scripts that are part of the AJAX demo's and tutorials.
> I assume I need to substitute either 'Fusion' or 'window.top.Fusion'
> somehow for
> '/parent.parent.parent.mapFrame.DigitizePoint(OnPointDigitized);'. /in
> my script however I have yet to do this in such a way that it works.
> I keep getting 'Object doesn't support this property or method'.
> So for example in my editmarkup.aspx code for example, I have the
> following function which should be activated when I click the digitize
> point button
> /            function AddPoint()/
> /                  SetDigitizeInfo(EDIT_POINT_HELP);/
> parent.parent.parent.mapFrame.DigitizePoint(OnPointDigitized);/
> In Fusion this code gives an error 'parent.parent,parent.mapFrame' is
> null or not an object
> I see that in MapGuideViewerAPI.js
> /function DigitizePoint(handler) {/
> /    if (handler) {/
> /      var Fusion = window.top.Fusion;/
> /      var mapWidget = Fusion.getWidgetById(mapWidgetId);/
> /      var digitizer = new Fusion.Tool.Canvas.Point(mapWidget);/
> /      digitizer.mouseUp = PointHandlers.prototype.mouseUp;/
> /      Object.inheritFrom(digitizer, Fusion.Tool.Canvas.prototype, []);/
> /      digitizer.initializeCanvas();/
> /      var activeWidget = mapWidget.buttonSet.activeButton;/
> /      mapWidget.buttonSet.setActiveButton(null);/
> /      digitizer.handler = function() {/
> /          handler.apply(null, arguments);/
> /          activeWidget.setActive(true);/
> /      digitizer.activateCanvas();/
> /      //add a listener to update the position of the features/
> /      mapWidget.registerForEvent(Fusion.Event.MAP_EXTENTS_CHANGED, /
> /        function(){/
> /          digitizer.updatePx();/
> /          digitizer.clearContext();/
> /          digitizer.draw(digitizer.context);/
> Thanks
> Fraser
> Important notice to recipients:
> Copies of documents that may be relied upon by you are limited to the
> printed copies (also known as 'hard copies') that are signed and
> sealed by the Engineer and/or Land Surveyor. Files in electronic
> formats, or other types of information furnished by the Engineer
> and/or Land Surveyor to you such as text, data or graphics are for
> your convenience only. Any conclusions or information obtained or
> derived from such electronic files will be at the user's sole risk.
> When transferring documents in electronic formats, the Engineer and/or
> Land Surveyor makes no representation as to long-term compatibility,
> usability, or readability of the documents resulting from the use of
> software application packages, operating systems or computer hardware
> differing from those used by McMahon Associates, Inc. at the beginning
> of the project.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090917/f186d7bc/attachment.html
