[mapguide-users] trouble connecting mapguide maestro postgis
Remco Houtkamp r.houtkamp at burohoutkamp.nl
Fri Sep 18 05:01:03 EDT 2009
Message is the same as yesterday when things did work. The lbpq.ddl is still marked when running depend.exe. ieframe.ddl is also marked and has a hourglass at the beginning of the line.
The meesage is as follows:
Error: At least one module has an unresolved import due to a missing export function in an implicitly dependent module.
Warning: At least one module has an unresolved import due to a missing export function in a delay-load dependent module.
Met vriendelijk groet,
Remco Houtkamp
BURO HOUTKAMP
|T: 06 14 390 205 |E: r.houtkamp at burohoutkamp.nl |P:  Kweldergras 21, 1441 WP, Purmerend |
-----Oorspronkelijk bericht-----
Van: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] Namens Zac Spitzer
Verzonden: vrijdag 18 september 2009 10:56
Aan: MapGuide Users Mail List
Onderwerp: Re: [mapguide-users] trouble connecting mapguide maestro postgis
try depends on  libpq.dll
On Fri, Sep 18, 2009 at 6:46 PM, Remco Houtkamp
<r.houtkamp at burohoutkamp.nl> wrote:
> You guys respond faster than I can check it! Great list!
> But... for some reason Test connection does not work anymore only difference
> is a restart of my laptop.
> Logfile tells me:
> <2009-09-18T10:40:23>                3508
> 127.0.0.1             Administrator
>  Error: An exception occurred in FDO component.
>         Unable to load the FDO Provider: (null)
>  StackTrace:
>   - MgFeatureServiceHandler.ProcessOperation line 83 file
> c:\osgeo\mapguide_21\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
>   - MgOpTestFeatureSourceConnection.Execute line 100 file
> c:\osgeo\mapguide_21\mgdev\server\src\services\feature\OpTestFeatureSourceConnection.cpp
>   - MgFdoConnectionManager.Open line 262 file
> c:\osgeo\mapguide_21\mgdev\server\src\common\manager\FdoConnectionManager.cpp
> Maestro gives the following error:
> De externe server heeft een fout geretourneerd: (559) MgFdoException.:
> Since installing/registering libpq.dll worked yesterday, I've redone that
> step... but no cigar... I'm trying to learn GIS for some months now, but the
> assumingly last obstacles are very hard to pass....
> Remco Houtkamp
> BURO HOUTKAMP
> WP, Purmerend |
> [mailto:mapguide-users-bounces at lists.osgeo.org] Namens Kenneth Skovhede,
> GEOGRAF A/S
> Verzonden: donderdag 17 september 2009 14:22
> ieshims.dll and ieframe.dll can be ignored.
> There should be no harm in copying the files, but it's not required.
> Now that you get that error, it is likely that the error.log contains extra
> information:
> 2.0.2: C:\Program Files\MapGuideOpenSource\Server\Logs\Error.log
> 2.1: C:\Program Files\OSGeo\MapGuide\Server\Logs\Error.log
> The MgConnectionFailedException usually means that the MapGuide service has
> stopped.
> Regards,. Kenneth Skovhede, GEOGRAF A/S
> Remco Houtkamp skrev:
> Been strugling along. Depend.exe told libpq.dll could not be opened. I
> googled for it, followed instructions and installed it. Now when I press
> test connections, it will not give me errors...seems like progress!
> I saved the data connection and tried to connect a layer. Maestro tells me:
> Failed to read schema from data source.
> The operation gave the error message: De externe server heeft een fout
> geretourneerd (Dutch for the external server returned an error): (559)
> MgConnectionFailedException.: Cannot establish connection.
> Depend.exe also says it cannot open ieshims.dll so I just copied it (is that
> ok) to the FDO folder.
> Now it only says Warning: At least one module has an unresolved import due
> It also shows a hourglass and some kind of red grid on an icon for the file
> ieframe.dll
> Verzonden: woensdag 16 september 2009 16:08
> try running depends.exe (google it) on the  postgis fdo provider dll
> sounds like the required postgres dll's are being found
> z
> On Thu, Sep 17, 2009 at 12:04 AM, Remco Houtkamp
> Hi all, this is my first post, still a newbie.
> I think I managed to import data from openstreetmap.org to postgis. But now
> I cannot connect. I guess things are working since I can connect from a
> program called Udig.
> In mapguide maestro I go through the following steps:
> Create a new resource>data connection
> OSGEO FDO Provider for Postgis
> Database: osm  (is visible in Udig)
> server: I tried localhost http://localhost/ 127.0.0.1 http:// 127.0.0.1/
> Port: 5432
> Tried all three credentials but think it must be Specified Credentials with
> user postgres and my secret password ;)
> Press test connection and then the following error appears:
> De externe server heeft een fout geretourneerd: (559) MgFdoException.: An
> exception occurred in FDO component. Unable to load the FDO Provider: Kan
> opgegeven module niet vinden. (some of this is Dutch...)
> My setup contains postgresql 8.4 and postgis 1.4.
> Can anybody tell me where I'm going wrong... struggling for days and days...
> and
> days...
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
