[mapguide-users] Implement redling with an always on top window
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Fri Sep 18 06:09:25 EDT 2009
I'm pretty sure you can't do that, as it would be really annoying and a
potential security risk
if arbitrary webpages could do that.
Instead, in the outer most page, include the viewer as an iframe:
<html>
<body>
<iframe src="......ajaxviewer/?....params..." style="... location, size,
etc ...."></iframe>
<iframe src="your-tool-window.html" style=".... same ..."></iframe>
</body>
</html>
You should now be able to place the second iframe on top of the first
one (z-index).
There are many JS snippets that allow you to drag an iframe around,
so you can just make the iframe look like a window.
That way, you can mimic an "always-on-top" window, but it stays within
the page, so the browser
does not mind.
Regards, Kenneth Skovhede, GEOGRAF A/S
Nick Sebastyan skrev:
> Greetings all,
> I have a question that is a little off topic but it implies mapguide
> at a certain level so i will give it a shot.
> I have to implement some redlining functionality on mapguide that will
> reside in a popup window because there are to much options and will
> not be very user friendly if i will put all this commands in the
> toolbar, context menu, taskpane etc.
> For example you have options to create, save as xml , rename, load,
> select, modify temporary layers, draw lines, polygons, insert text,
> insert symbols from the resource repository, etc.
> The idea is that the window that provide all this functionality will
> have to be an ALWAYS ON TOP window because it will be very annoying if
> the window keep losing focus when you start to draw something on the
> map. I have found some methods but they do not help because they give
> constant focus only to a window and it will not be possible to select
> what to draw and draw it this way
> ( an example will be window.showModalDialog('url', 'args')).
> So the question is does somebody know how you can truly make an
> "always on top window" or have other ideas ?
> Thanks.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090918/e5886abe/attachment.html
