[mapguide-users] SQLITE...and Mapguide/AJAX Multiple Selection
problem?
Traian Stanev
traian.stanev at autodesk.com
Tue Sep 22 20:40:59 EDT 2009
Well, considering this is FDO 3.3, which is seriously old, there probably isn't a build of the latest SQLite provider against FDO 3.3. It would have to be a custom build of the trunk 3.5 SQLite FDO code against the old FDO 3.3 libraries. I'll check how hard that would be to do, I'm guessing there is no chance for you to use FDO 3.4, given that you have deployed already?
Traian
________________________________________
From: mapguide-users-bounces at lists.osgeo.org [mapguide-users-bounces at lists.osgeo.org] On Behalf Of Scott hameister [scotth at mpowerinnovations.com]
Sent: Tuesday, September 22, 2009 7:51 PM
To: 'MapGuide Users Mail List'
Subject: RE: [mapguide-users] SQLITE...and Mapguide/AJAX Multiple Selection problem?
The Zip Was called FdoSQLiteProvider_3.3.0_r4270 11/26/2008 on
SQLITEPROVIDER.dll
MapGuide Server (Version 2.0.2.3011)
God I hope yopu are right...Where do you get the newer files?
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Traian Stanev
Sent: Tuesday, September 22, 2009 6:39 PM
To: MapGuide Users Mail List
problem?
What is the date of your SQLite dll (and what version of MapGuide, FDO)?
There have been numerous fixes done to the SQLite provider in the last few
months, and your problem has also likely been fixed.
Traian
Sent: Tuesday, September 22, 2009 6:23 PM
Selection problem?
I just noticed that making selections on any Layer in studio of multiple
objects has some odd results as well????
Anyone know why this is? I download my FDo driver from Jason birch's
Website...is there a newer one out there?
I finally got this customer entirely ported over to SQLite and now it looks
unusable...
PS just tried the fusion viewr in studio Selected a big square of
objects...the Fusion viewer shows I selected 84 objects based on the
selection tab, but the map visually only shows about 8 objects selected
randomly through my original box.
Anyone having success with multiple selections/or facing the same
problem.????????
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Flipper
Sent: Tuesday, September 22, 2009 5:08 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] SQLITE...and Mapguide/AJAX Multiple Selection
problem?
I'm Trying to utilize SQLITE in Mapguide...
I'm succesfully getting and creating selection filters with the API...I see
the Appropriate XML (see below)...
I sent this into the AJAX myframe.mapFrame.SetSelectionXML(selectionXml);
and refreshed and it only selects one object...I noticed the same problem
When I make a rectangular selection over several objects and it Reports back
only one objects...Im confused as to what is happening here....
Anybody else having any issues? Mapguide 2.0 OS
This is the Selection XML being sent into myframe.mapFrame.SetSelectionXML
<?xml version="1.0" encoding="UTF-8"?><FeatureSet
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:noNamespaceSchemaLocation="FeatureSet-1.0.0.xsd"> <Layer
id="0e2be5e2-0000-1000-8001-000423cc7e07"> <Class id="Default:SANPIPE">
<ID>EgAAAA==</ID> <ID>EwAAAA==</ID> <ID>FAAAAA==</ID> <ID>FQAAAA==</ID>
<ID>FgAAAA==</ID> <ID>FwAAAA==</ID> <ID>GAAAAA==</ID> <ID>GQAAAA==</ID>
<ID>GgAAAA==</ID> <ID>GwAAAA==</ID> <ID>HAAAAA==</ID> <ID>HQAAAA==</ID>
<ID>HgAAAA==</ID> <ID>HwAAAA==</ID> <ID>IAAAAA==</ID> <ID>IQAAAA==</ID>
<ID>IgAAAA==</ID> <ID>IwAAAA==</ID> <ID>JAAAAA==</ID> <ID>JQAAAA==</ID>
<ID>JgAAAA==</ID> <ID>JwAAAA==</ID> <ID>KgAAAA==</ID> <ID>KwAAAA==</ID>
<ID>LAAAAA==</ID> <ID>LQAAAA==</ID> <ID>LgAAAA==</ID> <ID>LwAAAA==</ID>
<ID>MAAAAA==</ID> <ID>MQAAAA==</ID> <ID>MgAAAA==</ID> <ID>MwAAAA==</ID>
<ID>NAAAAA==</ID> <ID>NQAAAA==</ID> <ID>OwAAAA==</ID> <ID>PAAAAA==</ID>
<ID>RQAAAA==</ID> <ID>RgAAAA==</ID> <ID>SAAAAA==</ID> <ID>SQAAAA==</ID>
<ID>SgAAAA==</ID> <ID>TQAAAA==</ID> <ID>TgAAAA==</ID> <ID>TwAAAA==</ID>
<ID>UAAAAA==</ID> <ID>UQAAAA==</ID> <ID>tAAAAA==</ID> <ID>tQAAAA==</ID>
</Class> </Layer></FeatureSet>
View this message in context:
http://n2.nabble.com/SQLITE-and-Mapguide-AJAX-Multiple-Selection-problem-tp3
696007p3696007.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
