[mapguide-users] SQLITE...and Mapguide/AJAX Multiple Selection
problem?
Traian Stanev
traian.stanev at autodesk.com
Tue Sep 22 21:07:05 EDT 2009
Yeah it will not work. I'll attempt to compile it with 3.3 and post again to the list whenever it's done.
Traian
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-
> bounces at lists.osgeo.org] On Behalf Of Scott hameister
> Sent: Tuesday, September 22, 2009 8:58 PM
> To: 'MapGuide Users Mail List'
> Subject: RE: [mapguide-users] SQLITE...and Mapguide/AJAX Multiple
> Selection problem?
> Id be willing to move up to FDO 3.4 But I thought Studio 2009 and
> Mapguide
> Open Source 2.0.2 Were Permanantly forced to use 3.3...Can I run 3.4 on
> these?
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Traian
> Stanev
> Sent: Tuesday, September 22, 2009 7:41 PM
> To: MapGuide Users Mail List
> Selection
> problem?
> Well, considering this is FDO 3.3, which is seriously old, there
> probably
> isn't a build of the latest SQLite provider against FDO 3.3. It would
> have
> to be a custom build of the trunk 3.5 SQLite FDO code against the old
> FDO
> 3.3 libraries. I'll check how hard that would be to do, I'm guessing
> there
> is no chance for you to use FDO 3.4, given that you have deployed
> already?
> Traian
> ________________________________________
> [mapguide-users-bounces at lists.osgeo.org] On Behalf Of Scott hameister
> [scotth at mpowerinnovations.com]
> Sent: Tuesday, September 22, 2009 7:51 PM
> Multiple
> Selection problem?
> The Zip Was called FdoSQLiteProvider_3.3.0_r4270 11/26/2008 on
> SQLITEPROVIDER.dll
> MapGuide Server (Version 2.0.2.3011)
> God I hope yopu are right...Where do you get the newer files?
> Stanev
> Sent: Tuesday, September 22, 2009 6:39 PM
> Selection
> problem?
> What is the date of your SQLite dll (and what version of MapGuide, FDO)?
> There have been numerous fixes done to the SQLite provider in the last
> few
> months, and your problem has also likely been fixed.
> Traian
> Sent: Tuesday, September 22, 2009 6:23 PM
> Selection problem?
> I just noticed that making selections on any Layer in studio of
> multiple
> objects has some odd results as well????
> Anyone know why this is? I download my FDo driver from Jason birch's
> Website...is there a newer one out there?
> I finally got this customer entirely ported over to SQLite and now it
> looks
> unusable...
> PS just tried the fusion viewr in studio Selected a big square of
> objects...the Fusion viewer shows I selected 84 objects based on the
> selection tab, but the map visually only shows about 8 objects selected
> randomly through my original box.
> Anyone having success with multiple selections/or facing the same
> problem.????????
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Flipper
> Sent: Tuesday, September 22, 2009 5:08 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] SQLITE...and Mapguide/AJAX Multiple Selection
> problem?
> I'm Trying to utilize SQLITE in Mapguide...
> I'm succesfully getting and creating selection filters with the API...I
> see
> the Appropriate XML (see below)...
> I sent this into the AJAX
> myframe.mapFrame.SetSelectionXML(selectionXml);
> and refreshed and it only selects one object...I noticed the same
> problem
> When I make a rectangular selection over several objects and it Reports
> back
> only one objects...Im confused as to what is happening here....
> Anybody else having any issues? Mapguide 2.0 OS
> This is the Selection XML being sent into
> <?xml version="1.0" encoding="UTF-8"?><FeatureSet
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:noNamespaceSchemaLocation="FeatureSet-1.0.0.xsd"> <Layer
> id="0e2be5e2-0000-1000-8001-000423cc7e07"> <Class id="Default:SANPIPE">
> <ID>EgAAAA==</ID> <ID>EwAAAA==</ID> <ID>FAAAAA==</ID> <ID>FQAAAA==</ID>
> <ID>FgAAAA==</ID> <ID>FwAAAA==</ID> <ID>GAAAAA==</ID> <ID>GQAAAA==</ID>
> <ID>GgAAAA==</ID> <ID>GwAAAA==</ID> <ID>HAAAAA==</ID> <ID>HQAAAA==</ID>
> <ID>HgAAAA==</ID> <ID>HwAAAA==</ID> <ID>IAAAAA==</ID> <ID>IQAAAA==</ID>
> <ID>IgAAAA==</ID> <ID>IwAAAA==</ID> <ID>JAAAAA==</ID> <ID>JQAAAA==</ID>
> <ID>JgAAAA==</ID> <ID>JwAAAA==</ID> <ID>KgAAAA==</ID> <ID>KwAAAA==</ID>
> <ID>LAAAAA==</ID> <ID>LQAAAA==</ID> <ID>LgAAAA==</ID> <ID>LwAAAA==</ID>
> <ID>MAAAAA==</ID> <ID>MQAAAA==</ID> <ID>MgAAAA==</ID> <ID>MwAAAA==</ID>
> <ID>NAAAAA==</ID> <ID>NQAAAA==</ID> <ID>OwAAAA==</ID> <ID>PAAAAA==</ID>
> <ID>RQAAAA==</ID> <ID>RgAAAA==</ID> <ID>SAAAAA==</ID> <ID>SQAAAA==</ID>
> <ID>SgAAAA==</ID> <ID>TQAAAA==</ID> <ID>TgAAAA==</ID> <ID>TwAAAA==</ID>
> <ID>UAAAAA==</ID> <ID>UQAAAA==</ID> <ID>tAAAAA==</ID> <ID>tQAAAA==</ID>
> </Class> </Layer></FeatureSet>
> http://n2.nabble.com/SQLITE-and-Mapguide-AJAX-Multiple-Selection-
> problem-tp3
> 696007p3696007.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
