[mapguide-users] SQLITE...and Mapguide/AJAX Multiple Selection problem?
Traian Stanev traian.stanev at autodesk.com
Wed Sep 23 12:03:22 EDT 2009
I posted builds of the latest SQLite provider code compiled against FDO 3.3 and also 3.4 at:
http://13-9.com/SQLiteProvider-3.3.zip
and
http://13-9.com/SQLiteProvider-3.4.zip
respectively. Due to differences in the FDO API, I had to hack around a bit of stuff, and I only gave the provider very rudimentary testing (I opened a sqlite file and read some data from it).
Let me know if there are still problems with selection, even with this new DLL. If there are, then I suggest you file a bug report against the provider and attach some sample data to it so we can debug it.
Traian
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-
> bounces at lists.osgeo.org] On Behalf Of Scott hameister
> Sent: Tuesday, September 22, 2009 9:18 PM
> To: 'MapGuide Users Mail List'
> Subject: RE: [mapguide-users] SQLITE...and Mapguide/AJAX Multiple Selection
> problem?
> THANKS
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Traian Stanev
> Sent: Tuesday, September 22, 2009 8:07 PM
> problem?
> Yeah it will not work. I'll attempt to compile it with 3.3 and post again to
> the list whenever it's done.
> Traian
> > Sent: Tuesday, September 22, 2009 8:58 PM
> > Selection problem?
> > Id be willing to move up to FDO 3.4 But I thought Studio 2009 and
> > Mapguide
> > Open Source 2.0.2 Were Permanantly forced to use 3.3...Can I run 3.4 on
> > these?
> > Stanev
> > Sent: Tuesday, September 22, 2009 7:41 PM
> > To: MapGuide Users Mail List
> > Selection
> > problem?
> > Well, considering this is FDO 3.3, which is seriously old, there
> > probably
> > isn't a build of the latest SQLite provider against FDO 3.3. It would
> > have
> > to be a custom build of the trunk 3.5 SQLite FDO code against the old
> > FDO
> > 3.3 libraries. I'll check how hard that would be to do, I'm guessing
> > there
> > is no chance for you to use FDO 3.4, given that you have deployed
> > already?
> > Traian
> > ________________________________________
> > [mapguide-users-bounces at lists.osgeo.org] On Behalf Of Scott hameister
> > [scotth at mpowerinnovations.com]
> > Sent: Tuesday, September 22, 2009 7:51 PM
> > Multiple
> > Selection       problem?
> > The Zip Was called FdoSQLiteProvider_3.3.0_r4270 11/26/2008 on
> > SQLITEPROVIDER.dll
> > MapGuide Server (Version 2.0.2.3011)
> > God I hope yopu are right...Where do you get the newer files?
> > Stanev
> > Sent: Tuesday, September 22, 2009 6:39 PM
> > Selection
> > problem?
> > What is the date of your SQLite dll (and what version of MapGuide, FDO)?
> > There have been numerous fixes done to the SQLite provider in the last
> > few
> > months, and your problem has also likely been fixed.
> > Traian
> > Sent: Tuesday, September 22, 2009 6:23 PM
> > Selection       problem?
> > I just noticed that making selections on any Layer in studio of
> > multiple
> > objects has some odd results as well????
> > Anyone know why this is? I download my FDo driver from Jason birch's
> > Website...is there a newer one out there?
> > I finally got this customer entirely ported over to SQLite and now it
> > looks
> > unusable...
> > PS just tried the fusion viewr in studio Selected a big square of
> > objects...the Fusion viewer shows I selected 84 objects based on the
> > selection tab, but the map visually only shows about 8 objects selected
> > randomly through my original box.
> > Anyone having success with multiple selections/or facing the same
> > problem.????????
> > [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Flipper
> > Sent: Tuesday, September 22, 2009 5:08 PM
> > To: mapguide-users at lists.osgeo.org
> > Subject: [mapguide-users] SQLITE...and Mapguide/AJAX Multiple Selection
> > problem?
> > I'm Trying to utilize SQLITE in Mapguide...
> > I'm succesfully getting and creating selection filters with the API...I
> > see
> > the Appropriate XML (see below)...
> > I sent this into the AJAX
> > myframe.mapFrame.SetSelectionXML(selectionXml);
> > and refreshed and it only selects one object...I noticed the same
> > problem
> > When I make a rectangular selection over several objects and it Reports
> > back
> > only one objects...Im confused as to what is happening here....
> > Anybody else having any issues? Mapguide 2.0 OS
> > This is the Selection XML being sent into
> > <?xml version="1.0" encoding="UTF-8"?><FeatureSet
> > xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> > xsi:noNamespaceSchemaLocation="FeatureSet-1.0.0.xsd"> <Layer
> > id="0e2be5e2-0000-1000-8001-000423cc7e07"> <Class id="Default:SANPIPE">
> > <ID>EgAAAA==</ID> <ID>EwAAAA==</ID> <ID>FAAAAA==</ID> <ID>FQAAAA==</ID>
> > <ID>FgAAAA==</ID> <ID>FwAAAA==</ID> <ID>GAAAAA==</ID> <ID>GQAAAA==</ID>
> > <ID>GgAAAA==</ID> <ID>GwAAAA==</ID> <ID>HAAAAA==</ID> <ID>HQAAAA==</ID>
> > <ID>HgAAAA==</ID> <ID>HwAAAA==</ID> <ID>IAAAAA==</ID> <ID>IQAAAA==</ID>
> > <ID>IgAAAA==</ID> <ID>IwAAAA==</ID> <ID>JAAAAA==</ID> <ID>JQAAAA==</ID>
> > <ID>JgAAAA==</ID> <ID>JwAAAA==</ID> <ID>KgAAAA==</ID> <ID>KwAAAA==</ID>
> > <ID>LAAAAA==</ID> <ID>LQAAAA==</ID> <ID>LgAAAA==</ID> <ID>LwAAAA==</ID>
> > <ID>MAAAAA==</ID> <ID>MQAAAA==</ID> <ID>MgAAAA==</ID> <ID>MwAAAA==</ID>
> > <ID>NAAAAA==</ID> <ID>NQAAAA==</ID> <ID>OwAAAA==</ID> <ID>PAAAAA==</ID>
> > <ID>RQAAAA==</ID> <ID>RgAAAA==</ID> <ID>SAAAAA==</ID> <ID>SQAAAA==</ID>
> > <ID>SgAAAA==</ID> <ID>TQAAAA==</ID> <ID>TgAAAA==</ID> <ID>TwAAAA==</ID>
> > <ID>UAAAAA==</ID> <ID>UQAAAA==</ID> <ID>tAAAAA==</ID> <ID>tQAAAA==</ID>
> > </Class> </Layer></FeatureSet>
> > View this message in context:
> > http://n2.nabble.com/SQLITE-and-Mapguide-AJAX-Multiple-Selection-
> > problem-tp3
> > 696007p3696007.html
> > Sent from the MapGuide Users mailing list archive at Nabble.com.
> > mapguide-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
