[mapguide-users] trouble connecting mapguide maestro postgis
Pedro Venâncio pedrongvenancio at yahoo.com
Fri Sep 25 09:24:09 EDT 2009
I also get the same error with the OGR Provider...
--- On Fri, 9/25/09, Remco Houtkamp <r.houtkamp at burohoutkamp.nl> wrote:
OGR did not work either… I wanted to test if the same thing
happens with mapguide 2.0.2, unfortunately it does not contain the postgis fdo.
So still no luck. I’m starting to worry that nobody will help me out. Can
somebody answer my other question? Does anybody have a similar windows xp setup
running and what versions do you use (postgresql, mapguide, postgis).
Van: mapguide-users-bounces at lists.osgeo.org
[mailto:mapguide-users-bounces at lists.osgeo.org] Namens Kenneth Skovhede,
GEOGRAF A/S
Verzonden: donderdag 24 september 2009 8:10
Aan: MapGuide Users Mail List
Onderwerp: Re: [mapguide-users] trouble connecting mapguide maestro
postgis
The OGR provider also supports PostGIS.
If you have given up on the PostGIS provider, you can try the OGR provider.
I belive Traian maintains a few updated OGR builds here:
http://13-9.com/
Regards, Kenneth Skovhede, GEOGRAF A/S
Pedro Venâncio skrev:
  Hello,
  I've got a similar problem.
  Starting at the beginning, I installed PostgreSQL 8.4 and PostGIS 1.4,
  MapGuide OS 2.1 beta1 and Maestro r4082 on Windows XP Pro with SP2 (IIS 5.1).
  By adding a datasource with the FDO Provider for PostGIS, the test connection
  fails. After, I added the bin folder of PostgreSQL (which contains the
  libpq.dll) to the environment variable - system path. From here, the test
  connection passed: “Provider reported no errors”.
  However, when I try to save the dataconnection (FeatureSource), appears this
  error message I send attached. Answering yes, when I try to create a layer,
  it shows the error in the second image.
  I've made the attempt with PostgreSQL 8.3.3-1 and PostGIS 1.3.3-1, but with
  the same results.
  Thank you!
  Regards,
  Pedro
  --- On Tue, 9/22/09, Remco Houtkamp <r.houtkamp at burohoutkamp.nl>
  wrote:
  I wrote an email for the fdo mailinglist with contains the
  information on this problem in an easy to read way (according to me). Maybe a
  summary is useful for this list as well, so here it is:
  Hi list,
  Somebody from the mapguide lijst told me
  about this list so I just subscribed. I ‘m new to this game and an newbie,
  but learned a lot the last couple of months.
  I finally managed to build the following
  setup:
  Winxp
  Mapguide 2.1
  Mapguide Maestro
  Postgresql 8.4
  Postgis 1.4
  I’ve filled the database (postgresql)
  with data from open street map with osm2pgsql. I can connect from Udig to
  postgis and from Quantum Gis (1.3 !!! 1.0 included with osgeo4w is not
  working). So my postgis setups works.
  In mapguide maestro I go through the
  following steps:
  Create a new resource>data connection
  OSGEO FDO Provider for Postgis
  Database: osm  (is visible in Udig)
  server: I tried localhost http://localhost/ 127.0.0.1 http:// 127.0.0.1/
  Port: 5432
  Tried all three credentials but think it must be Specified Credentials with
  user postgres and my secret password ;)
  Press test connection and then the following error appears:
  De externe server heeft een fout geretourneerd: (559) MgFdoException.: An
  exception occurred in FDO component. Unable to load the FDO Provider: Kan
  opgegeven module niet vinden. (some of this is Dutch... for cannot find the
  module)
  Somebody told me to test the fdo with
  depends.exe. This way we found out that libpq.dll is missing. After
  installing “ a version of libpq.dll” I was able to run the the test
  connection. It returned no errors and I save the connection. After this I
  need a layer to connect to the data. Unfortunately I ge the following error:
  geretourneerd: (559) MgFdoException.: (dutch for the external server returned
  an error)
  An exception occurred in FDO component.
  Unable to load the FDO Provider: (null)
  The errorlog tells me:
  <2009-09-18T10:40:23>
  3508
  127.0.0.1
  Administrator
  Error: An exception occurred in FDO component.
  StackTrace:
  - MgFeatureServiceHandler.ProcessOperation line 83 file
  c:\osgeo\mapguide_21\mgdev\server\src\services\feature\FeatureServiceHandler.cpp
  - MgOpTestFeatureSourceConnection.Execute line 100 file
  c:\osgeo\mapguide_21\mgdev\server\src\services\feature\OpTestFeatureSourceConnection.cpp
  - MgFdoConnectionManager.Open line 262 file
  c:\osgeo\mapguide_21\mgdev\server\src\common\manager\FdoConnectionManager.cpp
  It looks like the problem lies within the
  libpq.dll file. Anybody a thought on how to solve this problem...
  Thanks in
  advance, Remco  (The Netherlands)
  Namens Remco Houtkamp
  Verzonden: dinsdag 22 september 2009 8:26
  Onderwerp: RE: [mapguide-users] trouble connecting mapguide maestro
  postgis
  Jason, did not know of such list. I subscribed and off course
  will share when something comes out. I ‘m pretty sure it is a Mapguide FDO
  problem. After I’ve update Quantum Gis to v 1.3 (not included within the ever
  so useful osgeo4w) I’m able to connect to postgis from Quantum Gis as well
  besides Udig.
  If somebody here knows a solution please let me know. Do
  others experience the same trouble?
  Met vriendelijke groet,
  Remco
  Houtkamp
  BURO
  HOUTKAMP
  |T: 06 14 390 205 |E: r.houtkamp at burohoutkamp.nl |P:  Kweldergras 21, 1441
  WP, Purmerend |
  Namens Jason Birch
  Verzonden: maandag 21 september 2009 22:29
  postgis
  I haven't played with the PostGIS provider for a long
  time, but it would be key to ensure that you are using the same version of
  libpq (and the other postgresql client libraries) as the provider was
  compiled with.  I'm not entirely sure what version that is, but someone
  on the fdo-users mailing list should be able to help.
  Jason
  2009/9/21 Remco Houtkamp <r.houtkamp at burohoutkamp.nl>
  Been away for the weekend, so I couldn't continue. This
  morning I made a newe setup.
  Winxp
  Mapguide 2.1
  Mapguide Maestro
  Postgresql 8.4
  Postgis 1.4
  Same trouble as before with missing libpq.ddl, so I copied this file from the
  postgresql tot the mapguide FDO folde. Depend.exe showed me that there were
  some other files missing in the FDO folder so I copied them as wel. After
  this maestro returen no errors after adding a new
  connection>postgis>test connection. So I'm as far as I got before.
  When I add a layer and try to connect it, I get an error. The error log shows
  me:
  <2009-09-21T05:20:54>   2200
   127.0.0.1       Administrator
   Error: Cannot establish connection.
   StackTrace:
   - MgOpDescribeSchemaAsXml.Execute line 110 file
  c:\osgeo\mapguide_21\mgdev\server\src\services\feature\OpDescribeSchemaAsXml.cpp
   - MgServerFeatureService.DescribeSchemaAsXml line 333 file
  c:\osgeo\mapguide_21\mgdev\server\src\services\feature\ServerFeatureService.cpp
   - MgServerDescribeSchema.DescribeSchemaAsXml line 628 file
  c:\osgeo\mapguide_21\mgdev\server\src\services\feature\ServerDescribeSchema.cpp
   - MgServerDescribeSchema.DescribeSchema line 564 file
   - MgServerDescribeSchema.DescribeFdoSchema line 196 file
  Looking forward to reponds.
  -----Oorspronkelijk bericht-----
  Van: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org]
  Namens Zac Spitzer
  Verzonden: vrijdag 18 september 2009 11:11
  Onderwerp: Re: [mapguide-users] trouble connecting mapguide maestro postgis
  maybe adding the bin dir for your postgres client to your path,
  rather than adding just the dll to fdo?
  z
  On Fri, Sep 18, 2009 at 7:01 PM, Remco Houtkamp
  wrote:
  > Message is the same as yesterday when things did work. The lbpq.ddl is
  still marked when running depend.exe. ieframe.ddl is also marked and has a
  hourglass at the beginning of the line.
  > The meesage is as follows:
  > Error: At least one module has an unresolved import due to a missing
  export function in an implicitly dependent module.
  > Warning: At least one module has an unresolved import due to a missing
  export function in a delay-load dependent module.
  > Met vriendelijk groet,
  > Remco Houtkamp
  > BURO HOUTKAMP
  1441 WP, Purmerend |
  Namens Zac Spitzer
  > Verzonden: vrijdag 18 september 2009 10:56
  postgis
  > try depends on  libpq.dll
  > On Fri, Sep 18, 2009 at 6:46 PM, Remco Houtkamp
  wrote:
  >> You guys respond faster than I can check it! Great list!
  >> But... for some reason Test connection does not work anymore only
  difference
  >> is a restart of my laptop.
  >> Logfile tells me:
  3508
  127.0.0.1
  Administrator
  Provider: (null)
  >>  StackTrace:
  >> Maestro gives the following error:
  MgFdoException.:
  >> Since installing/registering libpq.dll worked yesterday, I've redone
  that
  >> step... but no cigar... I'm trying to learn GIS for some months now,
  but the
  >> assumingly last obstacles are very hard to pass....
  >> Remco Houtkamp
  >> BURO HOUTKAMP
  >> WP, Purmerend |
  >> GEOGRAF A/S
  >> Verzonden: donderdag 17 september 2009 14:22
  postgis
  >> ieshims.dll and ieframe.dll can be ignored.
  >> There should be no harm in copying the files, but it's not required.
  >> Now that you get that error, it is likely that the error.log
  contains extra
  >> information:
  >> 2.0.2: C:\Program Files\MapGuideOpenSource\Server\Logs\Error.log
  >> 2.1: C:\Program Files\OSGeo\MapGuide\Server\Logs\Error.log
  >> The MgConnectionFailedException usually means that the MapGuide
  service has
  >> stopped.
  >> Regards,. Kenneth Skovhede, GEOGRAF A/S
  >> Remco Houtkamp skrev:
  >> Been strugling along. Depend.exe told libpq.dll could not be opened.
  I
  >> googled for it, followed instructions and installed it. Now when I
  press
  >> test connections, it will not give me errors...seems like progress!
  >> I saved the data connection and tried to connect a layer. Maestro
  tells me:
  >> Failed to read schema from data source.
  >> The operation gave the error message: De externe server heeft een
  fout
  >> geretourneerd (Dutch for the external server returned an error):
  (559)
  >> MgConnectionFailedException.: Cannot establish connection.
  >> Depend.exe also says it cannot open ieshims.dll so I just copied it
  (is that
  >> ok) to the FDO folder.
  >> Now it only says Warning: At least one module has an unresolved
  import due
  >> to a missing export function in a delay-load dependent module.
  >> It also shows a hourglass and some kind of red grid on an icon for
  the file
  >> ieframe.dll
  Namens Zac Spitzer
  >> Verzonden: woensdag 16 september 2009 16:08
  postgis
  >> try running depends.exe (google it) on the  postgis fdo
  provider dll
  >> sounds like the required postgres dll's are being found
  >> z
  >> On Thu, Sep 17, 2009 at 12:04 AM, Remco Houtkamp
  >> Hi all, this is my first post, still a newbie.
  >> I think I managed to import data from openstreetmap.org to
  postgis. But now
  >> I cannot connect. I guess things are working since I can connect
  from a
  >> program called Udig.
  >> In mapguide maestro I go through the following steps:
  >> Port: 5432
  Credentials with
  MgFdoException.: An
  Provider: Kan
  >> opgegeven module niet vinden. (some of this is Dutch...)
  >> My setup contains postgresql 8.4 and postgis 1.4.
  >> Can anybody tell me where I'm going wrong... struggling for days and
  days...
  >> and
  >> days...
  >> mapguide-users mailing list
  >> mapguide-users at lists.osgeo.org
  >> http://lists.osgeo.org/mailman/listinfo/mapguide-users
  > Zac Spitzer -
  > http://zacster.blogspot.com
  > +61 405 847 168
  Zac Spitzer -
  +61 405 847 168
  -----Inline Attachment Follows-----
  _______________________________________________mapguide-users mailing listmapguide-users at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/mapguide-users
Skipped content of type multipart/related
