[mapguide-users] Change Layer Filter in Javascript
Mauricio Villablanca
mgvillablanca at yahoo.com
Fri Sep 25 20:10:12 EDT 2009
João Pereira wrote:
> Hello,
> I need to change the filter of a layer only in Javascript / Ajax, can´t
> use C# of php, can anyone help me.
> I have try the following :
> function RequestMap2(scale, centerX, centerY, idLayer)
> var reqParams = "OPERATION=GETVISIBLEMAPEXTENT&VERSION=1.0.0&SESSION="
> + sessionId + "&MAPNAME=" + encodeURIComponent(mapName) + "&SEQ=" +
> Math.random();
> reqParams +="&LAYER=" + idLayer + "&FILTER="+" ";
> mr = CreateRequestHandler();
> req = new MapRequest(mr, ++mapId);
> mr.open("POST", webAgent, true);
> mr.setRequestHeader("Content-Type",
> "application/x-www-form-urlencoded");
> mr.onreadystatechange = function()
> if(mr.readyState == 4)
> OnMapRequested(req, scale, centerX, centerY, mapId);
> try
> mr.send(reqParams);
> catch(e)
> return;
> Please help, thanks.
In order to set a filter you need to retrieve a layer definition, modify it,
save the map then refresh it. The 3 first steps can only be done at the
server level. You need to use either PHP or C#.
View this message in context: http://n2.nabble.com/Change-Layer-Filter-in-Javascript-tp3624682p3715624.html
