[mapguide-users] Mapguide 2.0.2 and SQLite
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Tue Sep 29 03:42:31 EDT 2009
Can you render the layer if you put it in a map?
The preview function tries to read the spatial context to determine the
display extents of the preview, but since that fails, it won't preview.
When you view the layer in a map, it won't try to read the spatial extents.
Regards, Kenneth Skovhede, GEOGRAF A/S
Flipper skrev:
> Traian Was Extremely helpful in getting a build of the SQLite drivers that
> were built on FDO 3.3 and 3.4 http://13-9.com/ LINK that work Extremely
> well for me on Mapguide Open Source 2.0.0...My problem is that it does not
> work on 2.0.2 Which is FDO 3.3.1, but discussing with him, Traian compiled
> with the latest code in the 3.3 branch, which is 3.3.1. It should not make
> any difference though, since 3.3.1 only has a few bug fixes on top of 3.3.
> And it still worked on 2.0.0 and not 2.0.2...Traian can';t really help me
> any further since this no longer seems to be an issue with the driver but
> with the MG release...THANKS SOO MUCH FOR YOUR HELP TRAIAN!!!!!
> I've USED the same versions of Maestro and of Mapguide Studio 2009 on my
> 2.0.0 product to Author out SQLIte layers...both work....
> On 2.0.2 Mastro gives me this error when I try to validate a data source
> connection ...
> Validating file:
> Session:663cacec-0000-1000-8000-002219fbc74d_en_7F0000010AFC0AFB0AFA//f4004ed7-a9ec-4586-8395-c94fb7121247.FeatureSource
> Warning - OSGeo.MapGuide.MaestroAPI.FeatureSource: No spatial contexts found
> Error - OSGeo.MapGuide.MaestroAPI.FeatureSource: Failed to read schema
> description: The remote server returned an error: (559)
> MgNullReferenceException.:
> Null reference.
> Exception occurred in method MgServerDescribeSchema.ExecuteDescribeSchema at
> line 62 in file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\feature\ServerDescribeSchema.cpp
> in Studio on 2.0.2 I get a "Null Reference" error When i try to do a preview
> on the Data connection and a Null Reference Pop up error and a Resource Id
> does not belong to a valid Feature Source Popup when i try to Create a layer
> from the datasource. Also in Studio the interface does not give me an area
> to enter a filename, on one machine, but on a machine where I did install
> the newest 3.3.1 FDo driver it does but doesnt give me a UseFdo metadata
> option like 2.0.0 did.
> Anybody have any ideas...Id just go to 2.1 myself or downgrade if it werent
> for the fact that its for others and not myself....Any help would be
> extremely appreciated
