[mapguide-users] EchoTest() - No data from standard input
kfwebb at bombasticlocution.com
Sun Apr 4 20:45:57 EDT 2010
mapagent and php work with this Apache handler config:
AddHandler fcgid-script .php
AddHandler mgmapagent_handler .fcgi
I still can't get stdin piped into mapagent when called via mod_fcgid
using:
AddHandler fcgid-script .fcgi
On Wed, 2010-03-31 at 21:48 -0400, kfwebb at bombasticlocution.com wrote:
> I am trying to debug a new MapGuide install, testing the
> ajaxviewersample.php against Sheboygan.mgp.
> All of my mapagent calls are failing. I have instrumented CgiAgent.cpp
> with a call to EchoTest(), and the following was dumped to the Apache
> log.
> <title>FastCGI echo</title><h1>FastCGI echo</h1>
> Request number 1, Process ID: 18312<p>
> No data from standard input.<p>
> Request environment:<br>
> <pre>
> PATH=/usr/kerberos/sbin:/usr/kerberos/bin:/usr/local/bin:/bin:/usr/bin:/home/kfw/bin
> LD_LIBRARY_PATH=/usr/local/mapguideopensource/webserverextensions/apache2/lib:
> PHPRC=/usr/local/mapguideopensource/webserverextensions/php/lib
> PHP_FCGI_MAX_REQUESTS=1000
> </pre><p>
> Any ideas why nothing is getting passed to mapagent?
> I am using mapguideopensource-2.1.0.4283 running on Red Hat el5.
> Thank you.
> KFW
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
