[mapguide-users] RE: MapGuide connection to SQL Server through ODBC
Warren Medernach wmedernach at rand.com
Tue Apr 6 16:34:53 EDT 2010
Well... A couple weeks and many testing scenarios later, we have figured
out what was happening in this instance of connecting to SQL Server
through ODBC.  So I thought I would post my findings in the event that
it might help somebody at some other time.
The SQL Server username password that we were using contained 'special
characters' like &, @, !, and MapGuide apparently could not pass these
properly.  Remember, the original error message thrown was:
response returned status code 502 (BadGateway)
It wasn't until we tested on a completely localized environment that a
more meaningful, only somewhat cryptic error message was thrown:
Feature Source - Unterminated entity reference, 'Bob'
'Bob' happened to be part of the SQL Server password we were using, and
more importantly, it was preceded by an '&' character.  I can only
assume that MapGuide could not properly pass the password.
Warren M
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Warren
Medernach
Sent: Tuesday, March 16, 2010 10:18 AM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] RE: MapGuide connection to SQL Server
throughODBC
Unfortunately, this is not what we are finding.
The DSN connection works fine from the MG server, but Studio (on a
clients desktop) is still failing when attempting to connect through
that same DSN.  There is an ISA server in the mix here and it seems to
be blocking the request from MapGuide.  Still working to resolve...
Warren M
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
Sent: Monday, March 15, 2010 3:40 PM
throughODBC
The issue I described would prevent you from testing the ODBC connection
within the ODBC Database Administrator in Windows. Basically if this
connection works then using the DSN in Studio should work. If you are
trying a connection string that might be a different problem. The DSN
definitely works.
Dave
Medermach (External)
Sent: Monday, March 15, 2010 3:12 PM
through ODBC
Thanks for the speedy response Dave!
I think I should clarify more.
If I create a UDL, or ODBC, connection on the MG Server machine to the
SQL Server on the other machine it works fine.  I'm trying to create a
connection to SQL Server from Studio via the ODBC FDO Provider and
choosing the 'Connect to a database' and 'Microsoft SQL Server' and then
specifying the credentials and proper connection string.  This is
failing.  So I'm not sure what MG is doing differently to communicate
with the SQL Server?
As for port 1433, that would need to be open on both machines for the
'handshake' communications, correct?  I wonder if that's the problem...
Warren M
Sent: Monday, March 15, 2010 2:29 PM
Subject: [mapguide-users] RE: MapGuide connection to SQL Server through
ODBC
I have an instance in house where the connectivity fails because of a
setting to do with the port in the ODBC configuration.
When setting up the ODBC configuration there is a button for Client
Configuration, click this and uncheck the dynamically determine port.
1433 should be shown in a grayed out box.
That might be the issue.
Dave
Sent: Monday, March 15, 2010 2:16 PM
Subject: [mapguide-users] MapGuide connection to SQL Server through ODBC
Hello all,
I'm trying to make a connection to SQL Server through ODBC using MG
Studio.
This works fine on a local test system where MG server & SQL Server are
installed on the same machine.
When deployed, MG Server is NOT installed on the same machine as SQL
Server.
In this scenario, I can create a UDL on the MG server machine and
successfully connect to SS with no problems.
However, when I try to create a data connection in MG, it fails with the
following error:
It would seem that something on the SQL Server machine is blocking the
connection request from MG.  So the question is, what is MG doing
differently than a simple UDL connection to communicate with the SQL
Server machine?
Any ideas, suggestions would be greatly appreciated.
MGE 2010
SQL Server 2005
Warren M
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100406/376087e3/attachment.html
