[mapguide-users] AW: Event that captures mouse action
vd
vd at plan-online.info
Thu Apr 8 11:08:56 EDT 2010
I think you do not point the viewerFrame (or however you named this frame!!!
this is the top of the ajaxviewer).
_____
Von: SriRam007 [via OSGeo.org]
[mailto:ml-node+4870628-1747384781-272960 at n2.nabble.com]
Gesendet: Donnerstag, 8. April 2010 14:09
An: vd
Betreff: RE: Event that captures mouse action
hi vd,
thanks for giving such a useful site
Just for learning I am trying to show the number of objects selected
Below is my code taken from that site But not working
Not showing the number of objects selected in alert box
///////****************************************/Handling viewer
selection/**********************************************************
//Function variable to store the original OnSelectionChanged
var origOnSelectionChanged = null;
//Our custom selection handler
function MySelectionHandler()
//This is important. We don't want to replace the original function,
rather
//we want to attach our code into the execution sequence. So we call the
original
//function first.
origOnSelectionChanged();
//Now our code goes here. For our example, we'll just show the number of
objects selected.
var count = viewerFrame.GetMapFrame().GetSelectedCount();
alert(count + " features selected");
window.onload = function()
//debugger
//Timer variable
var timer;
// This is our "watch" function. What we are doing here is
// repeatedly checking the mapInit value of the Map Frame. When
// mapInit is true, then the map has been loaded.
var watch = function()
// What we are doing here is attempting to access the mapInit
// variable of the Map frame. The reason the code is in a try-catch
// is because chances are that this code access the DOM
// of the map frame before its DOM has been initialized.
try {
//debugger
var mapFrame = viewerFrame.mapFrame;
if(mapFrame.mapInit)
// Remove the timer so this watch function stops executing
clearInterval(timer);
// Replace the OnSelectionChanged function with our own
function.
// It is safe to do this now because the DOM for the map
frame is fully initialized.
// Store old function
mapFrame.OnSelectionChanged;////Here not getting anything "Undefind" showing
// Now replace with our own.
mapFrame.OnSelectionChanged = MySelectionHandler;
catch(e) {
// Start the "watching" process. We basically invoke the watch function
// every 200ms until the map has been loaded.
timer = setInterval(watch, 200);
what might be the problem Please help me
thanks
_____
View message @
http://n2.nabble.com/Event-that-captures-mouse-action-tp3939442p4870628.html
To unsubscribe from RE: Event that captures mouse action, click
< (link removed)
uaW5mb3w0ODcwMTQ2fDEzOTkxODM0ODk=> here.
View this message in context: http://n2.nabble.com/Event-that-captures-mouse-action-tp3939442p4871694.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100408/7b99934b/attachment.html
