[mapguide-users] MGOS 2.1 server Crashes
siva4gis leo.shiv at gmail.com
Fri Apr 30 06:47:40 EDT 2010
I installed MGOS 2.1 in the following server configuration
HP DL580 G5 (Model), Intel Xeon 3 GHz Speed,2 processors (4 cores), 2*4 Mb
Cache,16 GB Ram.
i am using oracle 11g Spatial & SLking oracle provider. If 5 cocurrent users
access the application after 20 -30 min server crashes, its not showing map
even if manually i restart the service also some times its workig its taking
entire system restart.
below are the exceptions i seen in error log file
Error: Resource was not found:
Session:e8aa9210-35a8-102d-8000-002481922ff8_en_7F0000010AFC0AFB0AFA//Measure.FeatureSource
Error: Failed to stylize layer: Ward Boundary An exception occurred in FDO
component
Error: Failed to stylize layer: Shop An unclassified exception occurred.
Error: Session has expired or is invalid. Please log in again.
Thanks & Regards
Siva
View this message in context: http://osgeo-org.1803224.n2.nabble.com/MGOS-2-1-server-Crashes-tp4984968p4984968.html
