[mapguide-users] Mapguide 2.1 and ESRI ARCGis
Jason Birch jason at jasonbirch.com
Tue Aug 3 16:52:57 EDT 2010
If it's port conflicts:
- disable the mapguide service and any web apps (or apache if you
installed bundled configuration)  and reboot.
- use netstat to identify which ports arcgis server is using.
- reconfigure mapguide to use different ports. These are configured in
serverconfig.ini, webconfig.ini and -- if you're running apache --
httpd.conf
Jason
On 2010-08-03, Erik Heinze-Milne <heinzees at gmail.com> wrote:
> Has anyone tried to install Mapguide 2.1 and ARCGIS on the same server
> before? When I try Mapguide seems to take over ARCs connections, causing ARC
> not to work.
> Erik Heinze-Milne
> Home: (902)-442-6180
> Cell: 300-2187
> Programmer
> Landmark Geographic Solutions Inc
> www.gissolutions.ca
> www.geomapix.com
