[mapguide-users] MapGuide and Xamp
Jason Birch jason at jasonbirch.com
Tue Aug 3 17:03:22 EDT 2010
Assume you mean XAMPP?
Are you sure you need XAMPP?  MapGuide comes with a bundled Apache/PHP
install which may be an easier base to work from.
MapGuide requires specific versions of Apache (if you're using the
module instead of cgi) and PHP.  I'm not sure that either of these
conditions is met by and existing XAMPP distribution, but the current
version looks like a close match for the MapGuide 2.2 beta.
As far as making it work, you're pretty much on your own; nobody is
going to be able to provide step by step instructions.
It will likely mean doing a "bundled" install of MapGuide (which
includes PHP and Apache) on a different machine, figuring out what is
required by MapGuide, and grafting it into the XAMPP installation.
Not easy, and potential for version incompatibility is high.
Jason
On 2010-08-03, Rauf Ahmad <rauf.pucit at gmail.com> wrote:
> Hy every body !
> Its my first mail to this Discussion forum
> I want to configure the mapGuide with the Apache of Xamp plz help me bcz i m
> quite new in Mapguide.
> Thanks in Advance
