[mapguide-users] Re: FDO Exception when selecting feature.
Dave Wilson
dave.wilson at autodesk.com
Fri Aug 6 16:10:35 EDT 2010
It's a column in the spreadsheet, no different as if it was an Access table or other database table. It's in the named range.
Dave
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of DGK
Sent: Friday, August 06, 2010 2:06 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Re: FDO Exception when selecting feature.
Dave,
In the xml you sent (THANK YOU!) is the line <xs:key name="CountryKey">
Is "CountryKey" a field in your named range? Is it in the spreadsheet at
all or simply something the FDO needs?
Dan
View this message in context: http://osgeo-org.1803224.n2.nabble.com/FDO-Exception-when-selecting-feature-tp5347905p5381993.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
