[mapguide-users] Re: FDO Exception when selecting feature.
Jackie Ng jumpinjackie at gmail.com
Fri Aug 6 19:39:43 EDT 2010
The configuration doc is loaded as a stream inside your ODBC feature source
MapGuide Studio has no generic user interface to do this. It does have a
specialized editor for ODBC feature sources (it's near the bottom of the
feature source editor UI), that lets you specify custom identity properties
and geometry properties (from X, Y and Z columns).
In that grid, you would declare in your feature class "Data" that:
 - "Site ID" is the identity property
 - "LON" and "LAT" fields represent the X, Y geometry component properties
(though this probably isn't necessary, MapGuide did draw your points so it
detected these without issues).
- Jackie
View this message in context: http://osgeo-org.1803224.n2.nabble.com/FDO-Exception-when-selecting-feature-tp5347905p5382602.html
