[mapguide-users] RE: Window Selection (Ajax) as ENVELOPE or INTERESECTS Confusion
Haris Kurtagic haris at sl-king.com
Tue Aug 10 19:58:05 EDT 2010
Disjoint doesn't work either, that was bug from before.
Haris
On Wed, Aug 11, 2010 at 1:25 AM, Haris Kurtagic <haris at sl-king.com> wrote:
> Hi,
> In branch  3.5 is correct code, but in trunk and in my latest builds
> it is wrong code SDO_FILTER is used for Intersect.
> I will fix this in trunk and release new builds. There were other two
> issues fixed too.
> Haris
> On Tue, Aug 10, 2010 at 2:43 PM, Andreas Morf <a.morf at fkl.ch> wrote:
>> Crispin,
>> No, unfortunately not, the block I changed was within 'case FdoSpatialOperations_Intersects' where we should have the exact
>> intersection result set. With my configuration, this code block is called when selecting features or generating maptips.
>> Andreas
>>> -----Original Message-----
>>> From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf
>>> Of Crispin_at_1Spatial
>>> Sent: Tuesday, August 10, 2010 10:17 AM
>>> To: mapguide-users at lists.osgeo.org
>>> Subject: [mapguide-users] RE: Window Selection (Ajax) as ENVELOPE or INTERESECTS Confusion
>>> Andreas,
>>> Thanks for the help.  The changes you note were to support 9i - but
>>> something else has gone awry!
>>> http://trac.osgeo.org/fdo/ticket/619
>>> I am building the latest KingOra from the 3.5 branch and compiling into the
>>> Release_FDO_3_4 configuration and I don't see the old "1SPATIAL" comments in
>>> the source anymore:
>>> http://svn.osgeo.org/fdo/branches/3.5/Providers/KingOracle/src/Provider/c_KgOraFilterProcessor.cpp
>>> However, can you please conform that the code block you changed was in the
>>> switch/case for envelope intersects?
>>> If so then the original problem is still valid - because where
>>> "&SELECTIONVARIANT=INTERSECTS" this should not be calling the FDO operation
>>> for FdoSpatialOperations_EnvelopeIntersects.
>>>  Crispin
>>> switch( Filter.GetOperation() )
>>>   case FdoSpatialOperations_EnvelopeIntersects
>>> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Window-Selection-Ajax-as-
>>> ENVELOPE-or-INTERESECTS-Confusion-tp5389467p5392125.html
>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>> mapguide-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
