[mapguide-users] Re: Refresh map only
Warren Medernach wmedernach at gmail.com
Mon Aug 16 12:56:24 EDT 2010
Thanks Jackie!
That helped...  I created a function to call ExecuteMapAction from the
correct frame, and then I used the window.setInterval to call that function.
Now that its at least working, I'll poke around and see why the call to
Refresh() seemed to fail...
Warren M
On Sun, Aug 15, 2010 at 5:56 PM, Jackie Ng <jumpinjackie at gmail.com> wrote:
> Have you tried ExecuteMapAction(20), where ExecuteMapAction() is a method
> of
> the main frame and 20 is the command code for "Refresh Map"?
> - Jackie
> http://osgeo-org.1803224.n2.nabble.com/Refresh-map-only-tp5414227p5426321.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100816/589ae041/attachment.html
