[mapguide-users] Error When Printing in Fusion
Mars Wu
mars.wu at autodesk.com
Wed Aug 18 22:02:23 EDT 2010
Hi Wilson,
%s is the placeholder for the templ file. I guess you should replace all other "%" by "%%".
Thanks,
Mars
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Wilson Herrera
Sent: Thursday, August 19, 2010 4:11 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Error When Printing in Fusion
Good day,
i am working in some development for the fusion platform with mapguide.
one part of the development is to create custom print layouts, for that i tried to extend the native print widget but i have been experiencing this problem.
i tried to pass parameters on a single page, with excelent results ( you can see the result in the attached image capture.jpg). but when i try to "fuse"
it with the print widget i get the following exception
Warning: sprintf() [function.sprintf]: Too few arguments in C:\Program Files\Autodesk\MapGuide\WebServerExtensions\www\fusion\widgets\Print\printablepage.php
on line 63
i am sure that i wont have to modify the php code, but then the problem resides on my implementation ( filename: printablepage.templ attached to this message), i dont know where the error is, i have a very simple implementation that works well, but the main difference is the use of div's in this, while the first one, were just cells in a table ( can attach it if you need it ).
can you help me please to discover what is the reason for this error? thanks in advance.
dont hesitate to ask if you need adittional info.
Wilson
http://osgeo-org.1803224.n2.nabble.com/file/n5437688/Capture.JPG Capture.JPG http://osgeo-org.1803224.n2.nabble.com/file/n5437688/printablepage.templ
printablepage.templ
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Error-When-Printing-in-Fusion-tp5437688p5437688.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
