[mapguide-users] GDAL problems...
Jason Birch
jason at jasonbirch.com
Thu Aug 19 11:30:43 EDT 2010
Can you post an example image somewhere, along with details on its
projection and bounds, etc.
Also, a copy of the old and new FeatureSource XML and config XML
documents you've been working with.
Jason
On 2010-08-19, Andrew DeMerchant <andrew.demerchant at gemtec.ca> wrote:
> Looks like I'm on my own....which means stuck without any rasters.
> Andrew
> On 10/08/16 1:21 PM, Andrew DeMerchant wrote:
>> Anyone got any suggestions? I can provide a few of my rasters in
>> question, if need be.
>> Andrew
>> On 8/13/2010 5:11 PM, Andrew DeMerchant wrote:
>>> Sorry to add yet another GDAL question.....but for the life of me, I
>>> can't seem to get any new images working in MGOS (tried 2.0 and 2.2).
>>> If I debug and run the service interactively, I get a "(3656) An
>>> exception occurred in FDO component.
>>> Only MOSAIC(), CLIP() and RESAMPLE() are supported." message....I've
>>> seen that before, and had thought that it was coord related - but I
>>> can't even see a layer preview, and have tried the default coord
>>> system, as well the the correct one for my map. Can anyone offer some
>>> additional debug options here? My old rasters seem to still work - I
>>> just can't seem to add any new ones...
>>> GEMTEC Limited <http://www.gemtec.ca/>
>>> *Andrew DeMerchant*
>>> tel: 506.453.1025 / toll-free: 1.877.243.6832
>>> fax: 506.453.9470
>>> This e-mail message (including attachments, if any) is confidential and
>>> may be privileged. Any unauthorized distribution or disclosure is
>>> prohibited. Disclosure to anyone other than the intended recipient does
>>> not constitute waiver of privilege. If you have received this e-mail in
>>> error, please notify us and delete it and any attachments from your
>>> computer system and records.
>>> Ce courriel (y compris les pièces jointes) est confidentiel et peut être
>>> privilégié. La distribution ou la divulgation non autorisée de ce
>>> courriel est interdite. Sa divulgation à toute personne autre que son
>>> destinataire ne constitue pas une renonciation de privilège. Si vous
>>> avez reçu ce courriel par erreur, veuillez nous aviser et éliminer ce
>>> courriel, ainsi que les pièces jointes, de votre système informatique et
>>> de vos dossiers.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> de vos dossiers.
>> *Andrew DeMerchant*
>> fax: 506.453.9470
>> destinataire ne constitue pas une renonciation de privilège. Si vous avez
>> reçu ce courriel par erreur, veuillez nous aviser et éliminer ce courriel,
>> ainsi que les pièces jointes, de votre système informatique et de vos
>> dossiers.
>> dossiers.
> *Andrew DeMerchant*
> fax: 506.453.9470
