[mapguide-users] GDAL problems...
Jason Birch
jason at jasonbirch.com
Tue Aug 24 16:14:48 EDT 2010
Yeah, I think something changed in the way MapGuide deals with extents. I
think before it used a discrete call to determine the extents, but now is
using the spatial contexts? Or maybe the GDAL provider doesn't support the
call that MapGuide is now using? I'm not sure, but we definitely went
backwards in determining image layer extents between 1.2 and 2.x.
Sorry I didn't have time to look at the problem Andrew; glad Trevor did :)
Jason
On 24 August 2010 10:09, Trevor Wekel wrote:
> I was able to see the PNG image using MapGuide 2.2 build 5029. This
> build is a little newer than the beta but it should be similar as far as
> raster is concerned.
> In Maestro, I specified a coordinate system override on the GDAL feature
> source. Then I hacked up the extents on the map definition to get the PNG
> image on the screen. It looks as though MapGuide does not pick up the
> spatial extent properly from the png but still knows where the image is. I
> have attached an MGP with my test files. I took a guess on the coordinate
> system...
> I also used an external data file path (alias) when building the feature
> source – “Gemtec”
> Regards,
> Trevor
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100824/7ad031c4/attachment.html
