[mapguide-users] RE: Mapguide 2.2 Performance issue
Homan, Thomas
thoman at co.gila.az.us
Thu Aug 26 10:11:36 EDT 2010
Fantastic! Thank you Trevor
Tom
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Trevor
Wekel
Sent: Thursday, August 26, 2010 6:50 AM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] RE: Mapguide 2.2 Performance issue
I've started doing some documentation on serverconfig.ini and
webconfig.ini which includes a few tuning considerations
http://trac.osgeo.org/mapguide/wiki/ServerconfigWebConfigIni#TuningQuick
Links
As Dave has mentioned below, tuning is very dependent on data sets. As
such, the various tuning parameters may be different from install to
install.
Does "server not responding" mean a crash of the MapGuide Server
process? A crash on the MGO 2.2 64 bit Beta with only 10 concurrent
users seems unusual. If the crash can be easily reproduced with a small
data set, we should get a defect logged.
[Now for the shameless plug - sorry]
MapGuide Project Sponsorship or directly contracting MapGuide project
developers is an effective way to get defects addressed in a more timely
fashion. For myself, I do provide some "pro bono" work to the MapGuide
project but paid work necessarily takes priority. I suspect the same
statement would apply to other developers as well.
Regards,
Trevor
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Homan,
Thomas
Sent: August 25, 2010 5:06 PM
While this question is in the air...
Are there specific documents floating out there (Autodesk/OSGeo
generated) for tuning and capacity planning? The planning/deployment
guides are decidedly lacking on details but a section on basic tuning
would be quite helpful.
I've seen emails stating that various files need to be modified
(php.ini, *.config files, web admin and such) to maximize server use but
have never found anything specific.
Regards,
Tom
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
Sent: Wednesday, August 25, 2010 2:09 PM
Subject: [mapguide-users] RE: Mapguide 2.2 Performance issue
You will need to provide a lot more detail than "it doesn't work" to get
a useful response :)
What configuration are you using? .NET, APACHE etc..
Are you using Basic or Flexible Web Layouts? What kind of data/providers
are you using?
Are you using raster imagery and if so what format?
Yes the 64 connection limit has been removed, but other components
including the Berkeley database and physical disk I/O for example will
limit the number of concurrent connections?
What is your hardware? How many CPUs/cores? Is everything running on the
same box?
What are your users doing at the time things lock up?
Regards,
Dave
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Devadoss,
Bala (US)
Sent: Wednesday, August 25, 2010 3:02 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Mapguide 2.2 Performance issue
We just started testing 64 bit MGO 2.2 on windows 2008R2. When we load
tested our site with 10 simultaneous users, the Mapguide service stops
responding and we had to restart the service.
I thought MGO2.2 is fixed to handle around 500 connections at the same
time compared to 64 connections in MGO2.1.
Please throw some ideas for the performance issue.
Thanks,
Bala
This email is for the use of the intended recipient(s) only. If you have
received this email in error, please notify the sender immediately and
then delete it. If you are not the intended recipient, you must not
keep, use, disclose, copy or distribute this email without the author's
prior permission. We have taken precautions to minimize the risk of
transmitting software viruses, but we advise you to carry out your own
virus checks on any attachment to this message. We cannot accept
liability for any loss or damage caused by software viruses. The
information contained in this communication may be confidential and may
be subject to the attorney-client privilege. If you are the intended
recipient and you do not wish to receive similar electronic messages
from us in the future then please respond to the sender to this effect.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100826/4c061928/attachment.html
