[mapguide-users] error: Only one of 'complexType[@name=User]'
allowed ...
Giuseppe
info at comune.porcia.pn.it
Fri Aug 27 08:16:21 EDT 2010
... inside Schema Mapping element SchemaMapping[@name='Default'
I have 2 tables with same name (User i.e.) under different schemas in same
database (postgresql)
In Maestro i set an ODBC dataconnection, i configure columns for x-y
coordinates from another table of same database without problem. When
testing the connection i get the error.
Can I exclude these tables from my configuration document (without manually
edit XML!!!)?
I would do this work every time i reconfigure column in the dataconnection
(Maestro rewrites the configuration document loosing the editing...)
Thanks
View this message in context: http://osgeo-org.1803224.n2.nabble.com/error-Only-one-of-complexType-name-User-allowed-tp5469233p5469233.html
