[mapguide-users] Configuration Error in MapviewerNet in MGOS 2.1
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Tue Feb 2 03:02:21 EST 2010
From your error description:
*This error can be caused by a virtual directory not being
configured as an application in IIS*.
Have you configured the virtual directory as an application?
Regards, Kenneth Skovhede, GEOGRAF A/S
On 02-02-2010 06:23, padmini godavarthi wrote:
> Hi,
> iam using MGOS 2.1 and Maestro 1.0.9 on IIS 6.0
> vs 2005 express edition on Windows XP
> I have installed MGOS 2.1 and maestro 1.0.9 and created a package.the map is
> diplaying fine by show in browser
> But while developing a sample application i got the following error.
> Configuration Error
> Description: An error occurred during the processing of a configuration file
> required to service this request. Please review the specific error details
> below and modify your configuration file appropriately.
> Parser Error Message: It is an error to use a section registered as
> allowDefinition='MachineToApplication' beyond application level. This error
> can be caused by a virtual directory not being configured as an application
> in IIS.
> Source Error:
> Line 44: by Microsoft that offers a single logon and core profile
> services for member sites.
> Line 45: -->
> Line 46:<authentication mode = "None">
> Line 47:<!--forms name="ProgAspNetCookie" loginUrl="Login.aspx"
> Line 48:</authentication>
> Source File: C:\Program Files\OSGeo\MapGuide\Web\www\mapviewernet\web.config
> Line: 46
> so inorder to check mapviewernet is working or not i just typed
> http://localhost/mapguide/mapviewernet/ajaxviewer.aspx but the same error
> occurs.iam sending the error screenshot so that it will be easy and
> properties of Mapviewernet in IIS
> Note:I logged as a administrator
> shall i did any thing wrong?or is there any other properties i need to
> change?
> i worked on mgos 2.0 previously but no issues with that. i dont know why
> this happens in mgos 2.1
> plz anyboby help me so that it would be a great help.................
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100202/bcc58df8/attachment.html
