[mapguide-users] RE: Problem with map only half showing.
JamesDudden
jamesdudden at blueyonder.co.uk
Tue Feb 2 04:49:45 EST 2010
Crispin_at_1Spatial wrote:
> It looks like you are on MG 2.0.2 still? That is GDAL 1.4 so a copy of
> the GDAL v1.4.x latest (e.g. an old download of FWTools), stop the MG
> service and replace the GDAL dll -- restart and you should be OK
> Crispin
Hi Crispin,
Yes I am using MG2 and GDAL 1.4 so I tried adding GDAL 1.6 (the only
download I could find) but then the map didn't show up at all.
Is 1.6 too new? Which version do you think I should use and where can I get
it from?
Regards
JD
http://www.software-matters.co.uk Software Matters -
http://www.software-matters.co.uk/bespoke-database-design.html Bespoke
Database and Software Solutions
View this message in context: http://n2.nabble.com/Problem-with-map-raster-tif-files-only-half-showing-tp4473961p4499825.html
