[mapguide-users] Zoom To selection
andrea tiveron (e-metodi)
andrea.tiveron at e-metodi.it
Tue Feb 2 12:56:29 EST 2010
I have the same problem
I work with SDF
my code below is perfect to update a feature (it's a polygon)
my problem is when I select a feature and after update the feature on the
same map when I make a selection
the UpdateFeatures command work a lot of time, no error return, but the
value is not update
please help me
andrea
Dim realPath As String =
Request.ServerVariables("APPL_PHYSICAL_PATH")
Dim configPath As String = realPath + "webconfig.ini"
MapGuideApi.MgInitializeWebTier(configPath)
Dim userInfo As New MgUserInformation("Markup", "Markup")
Dim site As New MgSite()
site.Open(userInfo)
Dim sessionId As String = site.CreateSession()
Dim userInfoNew As MgUserInformation = New
MgUserInformation(sessionId)
Dim siteConnection As New MgSiteConnection()
siteConnection.Open(userInfoNew)
Dim resourceService As MgResourceService =
siteConnection.CreateService(MgServiceType.ResourceService)
Dim featureService As MgFeatureService =
siteConnection.CreateService(MgServiceType.FeatureService)
Dim dataSource As String = "Library://e-facility/SUAA/" +
namePlan + "/Markup/Data/" + nameLayer + ".FeatureSource"
Dim featureSourceId As MgResourceIdentifier = New
MgResourceIdentifier(dataSource)
Dim featureSourceExists As Boolean =
DoesResourceExist(featureSourceId, resourceService)
If featureSourceExists = False Then
Response.Write("<div
style=""text-align:justify""><b>Attenzione!</b><br />Non trovato!</div>" &
vbCrLf)
Response.Write("<script language=""javascript"">" & vbCrLf)
Response.Write("parent.functionTestConferma(false);" &
vbCrLf)
Response.Write("</script>" & vbCrLf)
End If
Dim className As String = "ambienti"
Dim filterText As String = "Key = '" + Trim(CStr(IDSpazio)) +
Dim queryOption As MgFeatureQueryOptions = New
MgFeatureQueryOptions()
queryOption.SetFilter(filterText)
Dim propertyValues As MgPropertyCollection = New
MgPropertyCollection()
propertyValues.Add(New MgStringProperty("Name", DesSpazio))
Dim updateFeatures As MgUpdateFeatures = New
MgUpdateFeatures(className, propertyValues, "Key = '" + Trim(CStr(IDSpazio))
Dim commands As New MgFeatureCommandCollection()
commands.Add(updateFeatures)
featureService.UpdateFeatures(featureSourceId, commands, False)
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Mbonnet
Sent: martedì 24 aprile 2007 17.15
To: mapguide-users at lists.osgeo.org
Subject: Re: [mapguide-users] Zoom To selection
hi, did you solved this problem because i have the same one
Farah-2 wrote:
> Hi Friends!
> I had posted this problem some time ago. But I wasn't able to come up with
> any solution to this. Does anybody have any pointers regarding the below
> mentioned problem?
> I am doing a search based on some condition and I am marking an existing
> layer with some markers. At the same time, I am adding these results to
> the
> map selection and I am zooming to the selected results using:
> parent.parent.SetSelectionXML(selectionXml);
> parent.parent.ExecuteMapAction(10);
> This works fine, the first time I do it. But if I do a new search, then
> the
> program hangs at this line:
> featureService.UpdateFeatures(parcelMarkerFeatureSourceId,
> parcelMarkerCommands, false).
> In fact, after a long time, it returns null. Is this an existing bug? Or
> is
> there some way to get around it?
> I am attaching my code as well. If someone has any idea, please reply!
> Regards
> Farah
> To unsubscribe, e-mail: users-unsubscribe at mapguide.osgeo.org
> For additional commands, e-mail: users-help at mapguide.osgeo.org
View this message in context:
http://www.nabble.com/Zoom-To-selection-tf2408316s16610.html#a10163084
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
