[mapguide-users] Re: MapGuideApiPINVOKE
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Wed Feb 3 04:40:34 EST 2010
Ok, it was as I suspected then.
You correctly load the MapGuideDotNetApi.dll, but it cannot call
MapGuideUnmanagedApi.dll.
The error message 0x8007007F seems to indicate that the dll itself was
found, but it is missing a method.
I'm unsure if the "missing method"-error means that the dll itself is
broken, or the method is simply missing.
Try using a tool such as "Process Monitor" to see what dll files it is
actually reading:
http://technet.microsoft.com/en-us/sysinternals/bb896645.aspx
Regards, Kenneth Skovhede, GEOGRAF A/S
On 03-02-2010 10:25, Gunter Becker wrote:
> The InnerException is:
> 'The type initializer for 'SWIGExceptionHelper' threw an exception'
> The InnerException of this Exception sounds a little bit weird (it's in
> german but I try to translate):
> 'The DLL "MapGuideUnmanagedApi": procedure could not be found. (Exception
> from HRESULT: 0x8007007F) cannot be loaded.'
> Please take a look at this screenshot to see the original
> http://n2.nabble.com/file/n4506237/Exception.jpg exception  text (german).
> Thanks in advance ,
> Gunter
