[mapguide-users] Map Name as a parameter for FUSION
Rodolfo Moreno rodolfoamoreno at gmail.com
Wed Feb 3 10:40:58 EST 2010
Hi all, I know that a map definition can be passed as parameter in fusion
viewer(theme parameter). However in my case I would prefer to pass the
mapname as parameter. Is it possible?
my use case is the following:
- I have a site with many pages. The user enter to the page where the fusion
viewer is loaded by default, it means without parameters. thus fusion
creates the map object (based on the mapdefinition of the appDefinition.xml)
and creates the map name too.
- Next the user could create other session layers through the task pane by
doing theming.
- Followed the user could go to other page and next come back to the page
where the fusion viewer is. In this moment the user should see the map such
as he/she left it. In this case it wuold be better load the fusion viewer
with the mapname as a parameter for both things: first because with the
mapname we can obtain the map with all modifications that the user did (e.g.
add layers) and second because we would avoid to create another map object
and hence we would consume less resources.
Regards,
Rodolfo Moreno
CivilEng
View this message in context: http://n2.nabble.com/Map-Name-as-a-parameter-for-FUSION-tp4507829p4507829.html
