[mapguide-users] Update SHP data problem
Jason Birch jason at jasonbirch.com
Thu Feb 4 22:23:29 EST 2010
Does this look familiar?
http://n2.nabble.com/Disappearing-Shape-File-Objects-td4113490.html
Jason
On 2010-02-04, Steve G <steve.golden at morganhill.ca.gov> wrote:
> I am using MGOS 2.02 and using Maestro to manage data connection, layers,
> maps, etc.  I have a data connection to an unmanaged SHP file on the server.
> I have been browsing the data via the php viewer for some time now.  I
> recently updated the data (added polygons and changed the attribute data),
> but did not change the filename.  Now when the php viewer pulls up the data,
> it has errors (polygons missing) and some of the polygons aren't selectable.
> If I save the data to a different shp file (data1.shp > data2.shp) and
> create a new data connection, layer, etc I do not have any problems.  I have
> tried creating new data connections and layers to the original file name,
> but nothing seems to correct the problem.  I would like to keep the old file
> name as I have a lot of other projects that reference that filename.  I
> don't know if there is some cache somewhere that needs to be cleared?  I
> have already restarted the service and server.  Any help?
> Thanks,
> Steve
> http://n2.nabble.com/Update-SHP-data-problem-tp4517874p4517874.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
