[mapguide-users] Studio Load Procedure and Maestro File add with Shapefile gets a 404 not found
Kori Maleski kori.maleski at gmail.com
Tue Feb 9 16:53:50 EST 2010
Has anybody encountered this scenario?
Using either Maestro or Studio to load a Shapefile results in a 404 not
found error.
No issues with any other shapefiles with the same load procedure or Data
resource setup from the exact same directory.
I can package the data and load it in order to bypass.
Stop/starting server has no effect.  There is caching enabled on
shapefiles.  Is there possibly a lock?  Shapefile opens and geometry has
been repaired in ArcMap, so I don't think it is data related.
Cheers,
Kori Maleski
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100209/db9b2475/attachment.html
