[mapguide-users] Re: problem when using same code for
MapGuideEnterprise2009 with MapGuideEnterprise2010
ehsan
ehsan85 at yahoo.com
Tue Feb 9 22:46:44 EST 2010
Sorry for the late reply, busy with assignment..when i get through the code
again i forget to give this code:
//create a multi-polygon or a multi-geometry containing the input selected
features
$inputGeom = MultiGeometryFromSelection($featureSrvc, $map, $selectionXml);
// Query all the features belonging the the layer list that intersects with
the input geometries
$fi = $renderingSrvc->QueryFeatures($map, $layerNames,
$inputGeom,MgFeatureSpatialOperations::Intersects, -1);
if($fi)
$resultSel = $fi->GetSelection();
if($resultSel)
$selxml=$resultSel->ToXml();//change the selection to
XML
$selection = new MgSelection($map, $selxml);//get the
Intersects Layer on the selection
$layers_selection = $selection->GetLayers();//get
layers
if($layers_selection)
for ($i = 0; $i <
$layers_selection->GetCount(); $i++)
$layer = $layers_selection->GetItem($i);
$selectlayer_name[$i]=$layer->GetName();
function MultiGeometryFromSelection($featureSrvc, $map, $selText)
$sel = new MgSelection($map, $selText);
$selLayers = $sel->GetLayers();
$geomColl = new MgGeometryCollection();
$agfRW = new MgAgfReaderWriter();
$polyOnly = true;
for($i = 0; $i < $selLayers->GetCount(); $i++)
$layer = $selLayers->GetItem($i);
// TODO: How to get $selectionSize?
$selectionSize = 20;
$filters = $sel->GenerateFilters($layer,
$layer->GetFeatureClassName(), $selectionSize);
$numFilters = $filters->GetCount();
for ($filterIndex = 0; $filterIndex < $numFilters; $filterIndex++)
$filter = $filters->GetItem($filterIndex);
if ($filter == "")
continue;
$query = new MgFeatureQueryOptions();
$query->SetFilter($filter);
$featureSource = new
MgResourceIdentifier($layer->GetFeatureSourceId());
$features = $featureSrvc->SelectFeatures($featureSource,
$layer->GetFeatureClassName(), $query);
if($features)
$classDef = $features->GetClassDefinition();
$geomPropName = $classDef->GetDefaultGeometryPropertyName();
$j = 0;
$isPoly = true;
while($features->ReadNext())
$geomReader = $features->GetGeometry($geomPropName);
$geom = $agfRW->Read($geomReader);
if($j ++ == 0)
$type = $geom->GetGeometryType();
if($type == MgGeometryType::MultiPolygon || $type ==
MgGeometryType::CurvePolygon || $type == MgGeometryType::MultiCurvePolygon)
$isPoly = false;
$polyOnly = false;
else if($type != MgGeometryType::Polygon)
break;
$geomColl->Add($geom);
$features->Close();
if($geomColl->GetCount() == 0)
return null;
$gf = new MgGeometryFactory();
if($polyOnly)
$polyColl = new MgPolygonCollection();
for($i = 0; $i < $geomColl->GetCount(); $i++)
$polyColl->Add($geomColl->GetItem($i));
return $gf->CreateMultiPolygon($polyColl);
else
return $gf->CreateMultiGeometry($geomColl);
i use these code to get the intersect with the select layer, i realize that
this code did not return any value from the function
MultiGeometryFromSelection..
thanks..
View this message in context: http://n2.nabble.com/problem-when-using-same-code-for-MapGuideEnterprise2009-with-MapGuideEnterprise2010-tp4492918p4545782.html
