[mapguide-users] RE: Problem with map only half showing.
Crispin_at_1Spatial
crispin.hoult at 1spatial.com
Thu Feb 11 09:23:40 EST 2010
James,
Long time no reply - found a machine that had one of out customised MG 2.0.2
installs.
See if this is OK. (but I'd still try and start a migration to 2.1 as long
as you are very careful with raster config files as the extents will be
wrong by default putting a lot of invalid load on the server)
Crispin
http://n2.nabble.com/file/n4554946/gdal14.dll gdal14.dll
View this message in context: http://n2.nabble.com/Problem-with-map-raster-tif-files-only-half-showing-tp4473961p4554946.html
