[mapguide-users] Studio Load Procedure and Maestro File add with
Shapefile gets a 404 not found
Kori Maleski
kori.maleski at gmail.com
Thu Feb 11 12:40:12 EST 2010
Thanks guys,
Nothing valuable in the logs.
I think live edits/load procedures on a MapGuide server that has cache
enabled for shapefiles is causing locking issues that a service restart
can't handle.
I need to do more testing and see what Fiddler shows.
Cheers,
Kori Maleski
On Wed, Feb 10, 2010 at 11:37 PM, Jason Birch <jason at jasonbirch.com> wrote:
> Anything in the system log, webserver log, or virus scan log on the server?
> Anything odd about the filename?
> Once the packaged data is loaded, are there any problems accessing the
> schema description?
> Red herrings, free for the asking :)
> Jason
> On 9 February 2010 13:53, Kori Maleski <kori.maleski at gmail.com> wrote:
>> Has anybody encountered this scenario?
>> Using either Maestro or Studio to load a Shapefile results in a 404 not
>> found error.
>> No issues with any other shapefiles with the same load procedure or Data
>> resource setup from the exact same directory.
>> I can package the data and load it in order to bypass.
>> Stop/starting server has no effect. There is caching enabled on
>> shapefiles. Is there possibly a lock? Shapefile opens and geometry has
>> been repaired in ArcMap, so I don't think it is data related.
>> Cheers,
>> Kori Maleski
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100211/078c6ccf/attachment.html
