[mapguide-users] Re: FDO/SQL formating expressions
oshan icycool at inbox.com
Thu Feb 11 23:54:04 EST 2010
Hey Jackie thanks for the reply.
How do I do the call GetCapabilities, to have a look at the supported
expressions?
Thanks
On Thu, Feb 11, 2010 at 4:21 PM, Jackie Ng [via OSGeo.org] <
ml-node+4553019-1333805880 at n2.nabble.com<ml-node%2B4553019-1333805880 at n2.nabble.com>
> wrote:
> The GetCapabilities mapagent call returns a list of supported expression
> functions for a given provider.
> The Maestro Expression Editor uses this list to provide "intellisense" for
> your current expression.
> So if you don't see a function that does what you want to do, you probably
> can't do it.
> - Jackie
>  View message @
> http://n2.nabble.com/FDO-SQL-formating-expressions-tp4512311p4553019.html
> To unsubscribe from FDO/SQL formating expressions, click here< (link removed) ==>.
View this message in context: http://n2.nabble.com/FDO-SQL-formating-expressions-tp4512311p4559458.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20100211/f932682f/attachment.html
